Checked underneath and it is dry. Leaks from bottom of door, usually on the right side. Machine is level side-to-side and front-to-back. Began leaking occasionally about 1.5 years ago. Now leaks every time it is run. Leaks a small amount -- no big puddles. If a dish or pot is placed in the front of the dishwasher, parallel to the door, it leaks more. All cycles seem to work and dishes are cleaning properly. Dishwasher is about 5 years old. Thanks for your help.
Bob
To my understanding, this is a known issue and GE has addressed this by replacing the door gasket. Please reference this page for more related information on the recall. Should you prefer to perform a DIY (do-it-yourself), the gaskets are readily available from most kitchen appliance parts center but have the exact model number ready. Pls start here or here. The gasket would look something like below.
available from here.
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
Main tub seal
Note… If the main motor of your dishwasher is mounted vertically, beneath the center bottom of the dishwasher, the following instructions probably apply to you. But if your motor is mounted horizontally, the pump isn't serviceable--you need to replace the entire pump and motor assembly.
The main tub seal is beneath the drain impeller. It prevents the water in the dishwasher from leaking out near the shaft of the motor. To get to the seal, which is inside the dishwasher, remove the:
Then pry the seal out of its housing and replace it.
Door gasket or seal
Over time, door gaskets and seals harden and lose their ability to seal properly. You can't repair the seals. You need to replace them if they've begun to leak.
Water-inlet valve
The water-inlet valve, itself, seldom leaks. But, the water-supply line from the house and the rubber tube leading from the valve to the inside of the dishwasher may leak. Tighten or repair/replace these as necessary.
The water-inlet valve could mechanically stick open. When that happens, the water continues to flow into the dishwasher, which then floods your kitchen. Turn off the water supply to the dishwasher, and replace the valve.
Hoses
Behind the lower access panel on your dishwasher are several rubber or plastic hoses. If the leak appears at a connection, try a new clamp. If that doesn't work, replace the hose.
Open the door have a look at the seal at the bottom of the door, after a length of time these seals degarade and have to be replaced
hope this helps
regards
Looks like a comprehensive answer to most leaks. Thanks. I think it's the door seal. If the tub was leaking, it would be wet underneath the dishwashern, not just below the door.
