Its only just started freezeing during a game;
You might check out the Informative article atEzinearticles.com to fix
the freezing problem as the articlegives the information about a DIY
guide, (though i don't remember thename of the site) but you can check
the article from http://ezinearticles.com/?Xbox-360-Freezing-Fix&id=1527369
Hello colin bernar,
There are two things that can be doing this, 1) the most likely; you have a bad disc, try using a different disc that is the same game. 2) unlikely but my still be the problem would be your xbox is running too hot and overheating which will freeze your game until the processor will cool down.
Hope this helps.
SOURCE: xbox 360 keeps freezing
Hi radz_01,
Your system is experiencing a 'general hardware error' and is destined to die very soon.
You should try the X-Clamp replacement fix (tutorials available on x-box scene) or you could try my own fix...
www.modelshop.4t.com
Click on News..
If you are still in warranty however, send it back to Microsoft and they should either replace or repair the console for free
*ChaHee* - What do you mean by 'lags' more explanation is needed here!
SOURCE: xbox 360 freezing during game play
Oh Wow, I am sorry to hear That dude. That has happened to me twice and i have heard to send it in to Cheap - O - Soft(Microsoft) to have it Fixed. What has happened to your Xbox is that it has Overheated, and now the CPU's ( Central processing units) Have broken off their sockets. What happens with the 360 is that when it gets so hot, the motherboard begins flexing against the CPU's, and their restraints called the X- clamps( The things that lock the CPU) and then the CPU breaks off. So your xbox keeps freezing Beacuse of that.
One thing you can do is to send it in to microsoft to have it repaired. just call 1-800-4MY-XBOX and then follow the instructions. But this only works if your xbox is under warranty.
If you are someone that is technically capable, you can open up your Xbox and fix it using this giude. It seems to have worked for many people and they have been glitch free for months. Here is the Link http://www.instructables.com/id/Fix-the-Red-Ring-of-Deathwithout-towels/ . Just follow this and repair your Xbox once and for all. However, that is only if you know and are sure that you are capable of working with delicate electronics. And i heavily reccomend that if your Xbox is still under warranty, that you send it in to them and have it reapaired. Takes about two weeks and is free. Ok then notify me if that works
SOURCE: My xbox keeps freezing 20 minutes into a game of Halo Wars
Most likely your GPU has a broken solder point on the mother board.
SOURCE: Xbox keeps freezing on the Microsoft Start-up screen
try clearing the memory cache
to clear the xbox 360's memory cache,
1. go to the system blade on your menu(should be the very last one)
2. go down to were it says memory, click on it. this should bring up
your hard drive or other storage devices, press a on the one you want
to empty
3. once youve gotten to the screen were it shows rename or format your
storage device, input Y,X,X,LB,RB,X,X and a prompt will come up asking
you if you want to empty your systems cache.
