Is there any way to identify the model number etc, on an old Tecumseh engine whose name plate in deteriated? I know B&S stampes info. on the cover but I'm not sure about Tecumseh.
SOURCE: i have an old lawnboy i need engine diagram
If you cant find one, I would suggest that you use a digital camera and take pictures during the disassembly. Then when you put it back together, just look at your pictures. Good luck...Lee
SOURCE: I have a Sovereign sv46d
Since you have a Briggs...and you have the OEM part number...go here:
http://www.ereplacementparts.com/
SOURCE: The gas line/hose (not sure what to call it
Hi.
I not only have found your fuel line available online, I also found the clamps and filters for your mower as well.
Here is a link to an online suppl;y company that caaries all the parts, and they ship rather quickly as well.
http://www.partsbuggy.com/ope/Toro-mower-ope-fuel-parts.htm
You may decide to get other parts from there as well, as they carry all the parts and accessories for Toro brand mowers.
I hope this helps you out, and have a good day!
SOURCE: Tecumseh 4.5 hp engine won't start
First thing to check on a Tecumseh; pull the half inch bowl nut (main jet) out of the bottom of the carburetor. Give it a good cleaning with carb cleaner then pay special attention to the teeny tiny hole that is right at the very top of the threads. It's so small you can hardly see it and if it clogs, your mower won't start. Best of luck to you.
The engine is on a 1970's era Snapper 308X rear engine mower. I think it is an 8HP engine. May not be the original engine that came on the mower. It had a name plate on the end of the engine but the name plate has fallen completely apart.
I need a new air filter and may need some carburator parts.
