Timex Ironman 30 Lap 53952 Wrist Watch Logo
Anonymous Posted on Nov 12, 2008
How the alarm works
I have a sharp watch that does not seem to have a model name, but it is black and gray, mostly plastic, water resistant to 165 feet, and the back says "China module." The four control buttons going clockwise starting from upper left are light, sts/stp, reset, and mode. Right now the alarm is now it is going off ever five minutes (the sound can be stopped by pressing sts/stp), starting from about 1:12 PM. I would appreciate an explantion of how to work the alarm so that I can turn it off and make adjustments
thanks, matt b.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Nov 13, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
378
Points
I controlled the alarm by keeping the start/stop (upper right) button depressed while repeadedly pressing on the reset (lower right) button.
2answers
Chronograph, sport watch, water resistant 165 ft. the alarm goes off in the middle of the night and I don't know how to set the alarm. All the web sites refer to A, B, C. Well I have reset, mode...
You can get instructions from the Amitron web site.
Copy "www.armitron.com/watch_instructions.asp" into your search engine
and you will see a list of illustrations of watches and associated
instructions.
Choose the one that looks like yours and download the PDF file.
This site gives an illustration showing the button labels, so it should solve your problem.
How to change the battery. I can't get the back off to get to it.
You need to take the watch to a watch expert. Most watches are not designed to be serviced by the owner. There are a couple of national chains of watch repair stores that specialize in battery replacement as well as a vanishing number of full-service watch repair shops. Most jewelers are not trained nor do they have the tools to do a proper battery replacement. Since this is a water resistant watch, make sure the place you take it to can re-seal the back and pressure test it to ensure the water resistance. The best place I've found is Precision Time. They are located in most major cities in major shopping malls and can service the watch while you shop. Check out www.precisiontimeco.com for nearest location. There are also a lot of FastFix locations around, but most are not able to reseal the watches.
1helpful
I bought my relic watch last year around christmas time it claims on the back of my watch it is water resistant up to 165 meters i haven't even gone close to that depth for the past 3 months or so my...
The most common failure of a watch to be water resistant is caused by a faulty contact between the case at an opening around the glass, crown, or pushbutton and the opening's gasket. Worn or defective rubber O-rings are often a cause of failure. Condensation forming under the crystal of a watch following a sharp temperature change (a swim after a stretch in the sun, for example) tells you to have the watch checked without delay. This can be an indication of additional moisture elsewhere inside the case. It is also the only water-tightness check a consumer can perform.
Of course non-water-resistant watches don't contain the additional seals and gaskets found on water-resistant models. Consequently, moisture-laden air can easily enter the case. Once inside, a pronounced change in temperature may cause condensation to form under the crystal. Very little can be done to prevent this. A high-quality water-resistant watch, however, properly serviced and maintained, will be sealed to prevent internal water damage and will more than outlast an ordinary watch.
To keep the watch properly sealed, replace any defective parts , such as gaskets, crystals, and crowns. Water-resistant watches should be tested for case tightness at least once a year, as well as every time the watch is opened, such as when a battery is replaced.
I have a fossil watch model fs4255 leather strap dress amber dial and I want to open back to remove old battery and replace with a new. i have a watch repair tool kit and replace all my own watch batteries...
mcdevito75 here, Even with the proper tools we still have to improvise at times, Instead of useing your case opener from your tool kit, use a steak knife or similar with a sharp edge inside that groove you"ve described, the cover will pry off.
2answers
I need user manual/instructions for Slazenger, model not known
mcdevito75 here, You can visit a small watch repair shop in your area for info, as some watch makers only deal with their watches commercialy.
Jun 27, 2010 • Watches
1helpful
My husbands new watch Armitron water resistant Quartz alarm chronograph, two tone blue face 20/1441 T205 ( water resistant 165 ft ) it came with no instruction manual,the alarm beeps every hour , anyway...
Copy "www.armitron.com/watch_instructions.asp" into your search engine and you will see a list of illustrations of watches and associated
instructions.
Feb 23, 2010 • Watches
Armitron wr165 ladies watch
WR 165 simply means Water Resistant to 165 feet. The model of your watch is stamped on the back of the watch face.
Check out this website for possible instructions, and at least they can sort of help you get started....
http://www.armitron.com/watch_instructions.asp
31helpful
4answers
Lost instructions to set my solo digital watch
I think I have the same watch and was just looking here to see if I could find how to stop the alarm going off every hour! However, I think I do know how to change the time: press the mode button three times (the first one brings up something like the stopwatch, the second brings up what may be an alarm time). On the third press you should get the time appearuing with the seconds flashing on the far right of the display. You can then change the second by pressing the"start" button. To change the minutes or hours, oress the "reset" button until they start flashing and use the start button again. pressing the reset button again will bring up the date to change. keep pressing until nothing is flashing any more and poress mode and it should bring you back to the current time. hope you can follow this and it works!
Top Timex Watches Experts
Paul Bade
NOEL
NOEL
Ngoro
Are you a Timex Watch Expert? Answer questions, earn points and help others
