2000 Toyota Celica Logo
Anonymous Posted on Apr 11, 2012
00 celica gts timing chain problems
I just bought a 2000 celica gts with 184000 miles and there is a humming form the front of the engine i thik its the timing chain that is loose i would like to know should i just change the tensioner or all related parts
  • Anonymous Apr 12, 2012
    ok thanks geoffw i'll start working on it
Geoffrey White
Level 3:
  • Toyota Master 3,965 Answers
  • Posted on Apr 11, 2012
Geoffrey White
Toyota Master
Level 3:
Answers
3965
Questions
Helped
915047
Points
10651
The timing chain should not routinely need changing, but perhaps the tensioner does.
Try first to eliminate any other causes, like the bearings in the fan, drive belt idlers, or alternator. A useful tool is a long screwdriver which you can apply to the various areas while placing your ear to the top of it while the motor idles.
Be very careful to keep clear of moving parts like fan blades.
Testimonial: "i tried the screw driver and the pulleys are ok i'll just order the entire timing kit and replace the parts that are faulty toyota gave me a quote of 899.80 for the timing chain and all related parts. "
5 Related Answers
Anonymous
  • Posted on Jun 29, 2010
SOURCE: 2003 Celica GTS fuel door problem!!!
I had the same problem and I drilled out the rivets...it does work after giving it a little time. You will be able to drill all the way through the rivet and then pull it out. You'll have to order a new hinge or door and reinstall the rivets. Can go to Harbor Freight Tools and get a rivet tool with rivets if you don't have one. They're not expensive.
Anonymous
  • Posted on Mar 22, 2009
SOURCE: 2004 toyota solara timing chain
You don't have to change your timing chain.. Timing chain last forever... If you don't hear any noise coming out from you engine, that means : nothing to worry about it... You can only adjust timing chain if there's any noise on the engine... Otherwise, just drive and go for fun... I have 2004 Solara and 110,000 miles already.. still runs great!.. My mechanic told me if I hear any noise like a chain noise, I have to see him for adjustment... I hope this message helps you...
Anonymous
  • Posted on Sep 06, 2008
SOURCE: 2001 Toyota Celica GTS Clutch
i paid a friend to do it because it's a lot of work! if you haven't already treid to or got it done just know that when my friend did it; it took him like 8 hours (he'd never done one on a celica, but had done them on american cars) so if your not familiar with it... not a good idea to do alone. I watched him do most, but i'm not the best to talk to about it.(plus i have a 2000GT) Some of the parts that i can remember that he took out to get to the clutch were the front driver's side tire, the axel on the same side, ....some other parts in there....and ALSO parts on top...the intake also had to be taken out just to have enough room to do the job. parts are cheap...just ask for a clutch kit at auto zone or whatever. around $150. another random tid bit that might help is make sure to tighten the engine mounts really good afterwards or else it will jump around in there when you turn it on and cut it off. buy gear oil before you start as well because you will need to put some in after the new clutch is in. i will need to put the car on a real lift... you need a lot of space underneath and on top to work. and most likely two people. well hope some of this helped.
johnjohn2
Johnny Brown
  • 5763 Answers
  • Posted on Oct 06, 2009
SOURCE: Toyota Celica gts 2000 blowing cold air when heater is on.
nothing try back flushing heater core, they clog up due to litle water preasure,you might want to flush cooling system if you already havent, hope this hleps.
Anonymous
  • Posted on Feb 07, 2011
SOURCE: TIMING CHAIN REPLACEMENT ON 18R TOYOTA MOTOR
here is the answer in detail
http://www.offroadforum.cz/toyota/aarc.epnet.com/application/8578/8578R03_Timing_Chain_and_Tensioner.html
What's mean late valve timing in toyota Celica 97 1.8L I have this problem.
Toyota Celica - Wikipedia, the free encyclopedia
https://en.wikipedia.org/wiki/Toyota_Celica
WikipediaVariable Valve Timing came in certain Japanese models starting in December 1997, and became standard in all models from 2000-on. Through seven ...
1970 - 2006 Toyota Celica History ' car review @ Top Speedwww.topspeed.com > Toyota > CelicaReview by Blas Nicusor - ‎Nov 28, 2006Nov 28, 2006 - 1970 nbsp - nbsp 2006 toyota celica history - DOC113627 ... The second generation Celica was released in 1978,(production began in late 1977) and ....the GT powered by an economical 1.8 L 4-cylinder 140 hp engine and the ... Toyota's signature VVT-i (Variable Valve Timing with Intelligence) system, ...Toyota Celica GTS (2003) - NetCarShow.com
Whats the max amount of miles you can drive on a 1990 toyota celica gts with the first engine?
If well maintained and with regular service this engine can last up to 150,000 miles. Remember, this means changing all fluids regularly, changing the hoses and belts regularly and just keeping the engine in tip top condition. No racing, no over revving, etc.
2helpful
WHEB TO CHANGE A TIMING BELT FOR A 2000 TOYOTA
Never as it does not have a timing belt but instead has a timing chain that requires no maintenance and should last the life of the engine.
I need to replace the water pump and timing belt in a 1990 Celica GTS but I need to transport the car 90 miles before doing it. I don't think the pump is too far gone but I don't want to lose the engine,...
water pumps usually only leak after shut down but no guarantees, you may also want to change oil pump o ring seal. It's right next to water pump, they get old and leak too.Oil pump o-riing and shaft seal very inexpensive from dealer,
3helpful
I have a 1988 celica gts coupe the heater works for about 1 mile in the morning then stops fan is ok.
The heater control panel needs to be removed and connections re-soldered. Common problem - the solder joints crack over time and the heater will default to the cold setting. At www.st162.net we have the DIY fix posted with photos. Cheers
2answers
2helpful
Transmission problem on 2001 Celica GT Auto Trans - how can I fix this?
I am glad my solution provided you with happiness. A gift, no, you do not need to do that. I appreciate the thought, though. The graciousness of a "FixYa" rating regarding my helpfulness would be GREATLY appreciated. That I all that I need form you. A happy Client. THAT is what FixYa is ALL ABOUT. Have a great week. Thanks again.
Engine mounts
who told u ther was 4?
ther is only 3
Top Toyota Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
ROBERT GARCIA
ROBERT GARCIA
Are you a Toyota Expert? Answer questions, earn points and help others
