Tip & How-To about Sony P6-120MP 8mm Tape
Try this:
1. make sure the tape is not loose - turn one end to tighten
2. make sure the head is clean - try a qtip or slightly damp swap long enough to reach and clean the head (silver drum but please be extra careful not to use to much force there is a litte haed that reads the tape and if you get any strands caught on here it will be hard to get out) the head will spin but clean and hold as much as possible because the head is harder to clean while spinning and the head is in between that has a very small slot to see it but it is close to the gapped seem of the haed
3. if you can fwd and rewind tape
4. make sure nothing is stuck in like and torn tape pieces
now sometime tapes of 120m are really not recommended because of the load of tape amd ost have a tension sensor 60m is usually the best recommended
