I am using Avery label template 5163 in what I believe is the 15 printmaster express program. It will duplicate one address for the whole page, but I cannot figure out how to get 10 separate addresses per page
SOURCE: I purchased printmaster gold 11 several years ago.
Check out this link at e-bay. This is the only place I could find for you. They have 2 days left on the auction at $6.25. Just copy and paste into your browser.
http://shop.ebay.com/i.html?_kw=printmaster&_kw=11&_ckw=gold
Hope this helps, let me know if I can help you with anything else.
JimmyC
SOURCE: how can i get my address book in printmaster 18
what program is using the address book? if it's outlook or outlook express just go up to the titlebar to filesin files there are 2 options import/export click thisjust do as the promt says and make sure you remember where the {NAME].csv file is being written on your drive. after that just copy the file to your thumb-drive and do the same process in reverse, using the import. OR<g> you could always just get frustrated and type it in manually(hope it's not to lengthy a list)
SOURCE: when I make labels I select"start from scratch"
Install The Print Shop's special fonts when running the automated installation process to ensure all toolbars and documents appear correctly in the software. If you bypassed this option and wish to install it later, click your Windows Start menu and select "Control Panel." Open the fonts control panel. Click "File" in the top menu bar and select "Install New Font." A dialog box will open. Navigate to C:\Program Files\Common Files\Broderbund\Core Fonts and press "OK."
Adjust your computer's hardware acceleration feature if the Print Shop's layouts or fonts appear distorted or overlap each other. Quit the program. Right-click your Windows desktop and choose "Display Properties" from the pop-up menu. Click "Settings" and press "Advanced." Push "Troubleshoot." Slide the adjustment bar for hardware acceleration one notch to the left. Close the window and resume use of The Print Shop 20. If the program's layout still appears jumbled, repeat this step and slide the bar one more notch to the left, repeating until the layouts no longer appear jumbled.
