RCA TruFlat  27F520T 27" TV Logo
Anonymous Posted on Apr 07, 2012
My rca remote does not have sap selection - RCA TruFlat 27F520T 27" TV
  • Anonymous Apr 07, 2012
    some channels are mute; some channels are in Spanish voice over. I cannot find the option SAP to turn of the SAP
    My menu options are: video, audio, closed caption, timer, language, setting, vchip;
    In language, I've selected English; in Audio, I've selected equisound;
Warren Doll
Level 2:
New Friend:
  • Expert 51 Answers
  • Posted on Apr 07, 2012
Warren Doll
Expert
Level 2:
New Friend:
Answers
51
Questions
0
Helped
31756
Points
147
In the user guide there states to push MTS button, manual here
http://www.manualowl.com/m/RCA/27F520T/Manual/38970
  • Anonymous Apr 11, 2012
    Thank you, Warren, but this is not the manual for my tv. My tv is an RCA B27TF680 TV, and the remote control does not have an MTS button. I've checked the manual for our TV, but I'm not seeing a solution.
    Any other ideas?
Turn off stereo sap in tv
buy an rca universal remore for 8.00
4helpful
How to I disable the SAP function on RCA FLAT 19 INCH screen?
Hello
From its main Menu, surf towards its sound Menu.
By using UP/DOWN buttons of the remote handset, select SAP
SAP (Second Audio Program) (for analog channels only) Plays the
program's audio in a second language, if one is available. The TV displays
the word SAP in the channel banner when you tune to a program that is
broadcast with SAP information. SAP audio is broadcast in mono. SAP is also
used to broadcast a program's audio with descriptions of the video for the
visually impaired. Press the right arrow button to turn SAP on or off.
OK.
I have a 2002 RCA, TV , Model #B27TF680 and some chan. are in Spanish, some in English and some do not have any sound. SAP is on and the remote does not offer any way of turning it off....Please...
You can simply go to the menu screen by clicking the 'menu' botton on the remote and select 'sound' to fix it. (Sometimes the word 'sound' will be replaced by ' voice', 'FM', 'AM' etc.)
1helpful
How do I get my rca truflat tv to get out of mono?
Hello
Press the MTS on the remote control handset to select STEREO, MONO or SAP. All the options will be available only when the current TV channel is broadcasting that option. Channels will not always carry programes, that have all MTS options. If "STEREO" appears on the screen when you select a channel means stereo sound is available with current programme. You can hear sound from both speakers. If broadcast is not strong and clear, stereo sound will not be available. Press "MTS" button to change it to "Mono". This will eliminate the noise. If "MONO" appears on the screen when you select a channel, stereo effect will not be availabe, even though you have set it to stereo. If "SAP" appears when you select a channel 'Second Audio Programe' [SAP] broadcasting is available for that programme. Press the "MTS" button to 'SAP' and you can hear that programe in different language or some other kind of audio.
I can get a picture , but no sound on the TV . What am I doing wrong?
Many RCA TV sound problems are caused by SAP function being activated by TV station equipment that converts Analog TV signals to HD signals. Accidental pressing of the wrong buttons on your remote can also cause this problem.
The incorrect conversions causes the Audio settings to be changed from Stereo to SAP by the received signal.
Solution is to go to Audio set-up in customer menu and change settings from SAP to Stereo. If you find that settings are wrong, change them to "Stereo". Do channel scan if you are using the TV tuner/remote to select channels. Turn off the TV and unplug for 60 seconds. Check the settings again and reset if required.
This problem may re-occur when you select the VHF channel, satellite channel or cable box channel that is causing the problem. It is not a TV fault that can be repaired. The problem is caused by the incorrect incoming signal.
SAP is Second Audio Program, used for second language transmissions.
Second cause may be that the speakers have been turned off in the audio set-up menu.
easyab
How do I remove the ''sap'' setting without the original rca remot?
You can use your front panel buttons & it should tell you (display) which button does does what function.
TV in SAP mode and cannot remove. Lost original remote.
I had the same problem. You have to order a replacement remote with the MTS button (Multi Channel Sound)
Call RCA Support @ 1.800.338.0376 I believe the remote part number is RCR130TB1
Turning the sap off using my universal remote
If there are any menu setting buttons on the t.v. itself then I would try using them to find the sap setting.
No sound
Hi, It seems that the SAP, no audio, distorted audio is a common problem for some RCA units even with the use of the original remote and in your case made more difficult with a replacement remote. Two things you can try: 1. Some say that unplugging the TV set for a long time, a couple of hours at least will do a hard/system reset on the microcontroller inside the TV hopefully resetting set-up the audio (including SAP) to default; 2. contact Customer Support at Thomson and explain your problem; 3. Try going a google on "RCA SAP manual reset"; or 4. Buy an original remote and not another replacement. Hope this work out for you and give you some ideas. Pls post again how things turn up. Good luck and kind regards.
No sound on two local channels?
Do you have the original remote? it will look like the one here:http://www.remotes.com/remotes/servlet/rs?a=gmi&smodel=B27TF680&brand_pn=RCA_B27TF680&mode=large&uid=11758883061400 If you do not have the original remote you will not be able to switch off the SAP setting, without it as there is a button that controls the sound. when this button is pressed you see where to turn off the SAP setting. Good Luck
Top RCA Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
