When I push the single button above the row of three buttons on the circuit board while turning on power Button I get a code which says ( pr 3) other than that i still get the beeping and the err 13 code and the buzzer.
SOURCE: juki will not go in
http://www.singernj.com/shop/Juki-DDL-8300.html
If this is the machine you have, that BIG horizontal lever on the right is the reverse lever. You must have some sort of electronic reverse mechanism that is externally mounted. You need to post info on that mechanism.
SOURCE: juki tl98q will not run
Is your bobbin threader pulled over? If it is the machine thinks your trying to fill a bobbin.
pushing the 3 buttons and the turn on button at same time , reset the machine and wiped error codes . Motor brings needle up to park and when I start to push pedal it goes down and stops in the bird nest. I need to get finer thread . AABOSID is the man for answers. Thanks .
