To adjust the clutch on suzuki king quad 1999 locate the oil filter on the right side of the bike look for three bolts with a bigger one in the middle of the threethe middle srew will open up a nut and a set screw in the middle loosen the the nut and turn the the adjustment screw while you are in first gear . hope this helps you
Verify that the shift cables are making a complete shift at the tranny, if the cable has failed or stretched, it may not be shifting completely. Most Suzuki King Quads have a metal shift rod on the left side which select low high and super low. And also have a shift lever on top. The vin number is usually located on the rear uprights behind the seat. Also there is usually a date stamped on the seat itself that may help.
