SOURCE: Bypassing the parking brake safety
This is illegal to do in many states so it is not recommended that you bypass the saftey feature and can result in you being ticketed and fined. On this unit, for testing purposes, you would ground the parking brake wire and the screen should come on and stay on.
SOURCE: bypass for video on a kenwood ddx-512 car dvd player
On the wiring harness there is a green parking sensor wire (PRK SW) that you have to hook up. All you have to do is ground that anywhere on the chassis of the car then youll be set.
SOURCE: bypass parking brake for dvd player Kenwood kvt 512
With my BMW I had to connect both the solid blue (pwr ant) wire and the blue with white stripe (p conn) to the solid blue wire from the factory harness. It isn't obvious that either of these are needed as the KVT-512 has it's own power supply but the way most factory power amps are installed the power from the KVT-512 is not used and the car manufacturers power amp needs to be turned on. If you are listening to the radio the pwr ant wire will turn on the power amp, this didn't seem obvious because the BMW doesn't have a power antenna. And when you are using the DVD player or the iPod connection you need the P Conn wire to turn on the car power amp as the ant pwr is disabled because you are no longer using the radio and Kenwood assumes you will not need the antenna so no power to this lead. Solder all three wires together and you should have sound all the time.
