At & t windows mobile phone.
If you want to use your mobile with other country means, unlock your mobile..This unlocking can be done through codes.If you wanna code, get it from http://www.mobileunlocksolutions.com/ .It helps to unlock your mobile easily.
SOURCE: how i can reset my phoe
To hard reset your phone, hold down the d-pad up button while turning on your phone.
SOURCE: SGH-i607
I have the SGH-i617 and got it unlocked. I am not sure if the same code can be used for the i607 - but here it is, give it a try:-
#0111*59428207# or just put in 59428207, you have to do this with sim in.
good luck
SOURCE: I need remote code to unlock Samsung Blackjack SGH-I607
FIRST REMOVE THE BATTERY AND THEN SIM CARD.
PLACE BATTERY BACK IN AND THEN TURN PHONE ON.
NOW PRESS: #7465625*638*75297038# (THIS WILL BRING UP NUK BOX)(NETWORK UNLOCK KEY)
THEN PRESS IN: 75297038
IF DONE CORRECTLY IT WILL SAY SYSTEM UNLOCKED.
NOW PLACE ANY SIM FROM ANY CARRIER AND ENJOY....
IF THIS WAS SUCCESSFUL, PLEASE REPLY BACK WITH A SIMPLE THANKS....
SOURCE: i need a GPRS settings
1. Go to Application
2. Go to Java world
3. Go to My games ( or the folder for new applications)
4. Go to where you have your Opera Mini
5. Click options and scroll to settings
6. Select your prefered config. setting
7. Edit and mark where you have "Proxy"
8. Underneath input the IP and Port
9. Go to Advanced settings to check wheather APN, User ID and Password are intact.
10. Save and Activate.
