20 Most Recent
Samsung Bargaincell Original OEM Accessory Bundle SGH T809, D820, SGH T509, SGH D807, SGH T519 Trace, SGH T629, Sync SGH A707, SGH D900, Blackjack SGH I607, SGH T629, Ph M610, Sch U420, Sch U740, SGH T219 Questions & Answers
T629 reset code
try using these codes:*2767*2878#or*2767*3855#note: you need to take out the sim card first before you do this. put it back only after the phone restarts
5/20/2012 3:40:08 PM •
Samsung...
Answered
on May 20, 2012
Unlock network lock samsung sgh-m610
You'll need to purchase an unlock code.You will probably find a number of companies via google a I have used a couple, which I'm not sure I'm allowed to post here so I recommend you visit
Unlock-Zone.com, which is nearly perfect and they were recommended highly in the cell phone forums.Click the unlock your phone and select the mobile phone, current service provider to get the available unlocking service which ranges from $5 to about $25, depending on the model of phone you have.
11/8/2011 3:26:34 PM •
Samsung...
Answered
on Nov 08, 2011
A friend gave me an
If your IMEI is coming up as 00000 0000 000 then your phone is essentially a brick. No codes or new sim cards will change this, plus no phone retailer or mobile unlocking business in your high street is going to go anywhere near it because they will be scared that its a stolen handest.
The only solution is to plead with someone in a mobile phone shop that you followed an idiots advice on the internet and typed the code *#7337# and reset your IMEI and you want it changed to the original IMEI on the back of your handest, or possibly send the phone back to the retailer. Will cost at least £20 to sort this out and allot of hassle im afraid to anyone who has done this.
2/12/2011 9:42:21 PM •
Samsung...
Answered
on Feb 12, 2011
I did put #*7337# =
go to your settings and go to connections or connectivity. and network selection and do a search for you network.
11/13/2009 6:15:26 AM •
Samsung...
Answered
on Nov 13, 2009
Why is there 2 Apps on my samsung device, Phone 12.00KB Phone 12.45MB
Pode haver v?rios motivos pelos quais voc? tem dois aplicativos no seu dispositivo Samsung com tamanhos diferentes, mesmo que ambos estejam relacionados ao telefone. Aqui est?o algumas poss?veis explica??es:
1. **Atualiza??es do Sistema ou Operadora:** ?s vezes, as atualiza??es do sistema operacional ou da operadora podem resultar em duas vers?es do mesmo aplicativo. Uma pode ser a vers?o anterior que ainda est? no dispositivo, e a outra ? a vers?o mais recente.
2. **Pr?-instala??o e Atualiza??o:** Alguns dispositivos v?m com aplicativos pr?-instalados de f?brica, e esses aplicativos podem ser atualizados posteriormente atrav?s da loja de aplicativos, resultando em duas instala??es coexistentes.
3. **Armazenamento Local e na Nuvem:** Alguns aplicativos possuem a op??o de armazenar dados localmente no dispositivo ou na nuvem. Isso pode resultar em duas instala??es, uma para dados locais e outra para dados na nuvem.
4. **Configura??es Diferentes:** Dependendo das configura??es, um aplicativo pode ter duas instala??es separadas para lidar com diferentes contas ou configura??es.
Para resolver esse problema, voc? pode tentar o seguinte:
- Desinstalar a vers?o mais antiga ou menor do aplicativo, especialmente se voc? tiver certeza de que a vers?o mais recente ou maior ? funcional e atende ?s suas necessidades.
- Verifique se ambos os aplicativos s?o, de fato, vers?es diferentes do mesmo aplicativo. ?s vezes, nomes semelhantes podem ser enganosos.
Lembre-se de que o processo espec?fico pode variar dependendo do modelo do seu dispositivo Samsung e da vers?o do sistema operacional. Se voc? tiver d?vidas ou n?o se sentir confort?vel fazendo essas altera??es, ? sempre urgente consultar a assist?ncia do suporte t?cnico do fabricante ou do seu provedor de servi?os.
How do i remove lock screen on my samsung j4 core,
HardReset.info:
How to hard reset SAMSUNG Galaxy J4 (2018)
- Hold down the Power key for a few seconds to switch off the device.
- Then start pressing Volume Up and Power buttons together for a couple of seconds.
- Let go of all buttons when you see the SAMSUNG logo.
- If the Android Robot with "No command" image pops up you should tap on the screen.
- In this menu choose "wipe data/factory reset" by using Volume keys to navigate and the Power button to accept it.
- After that select "Yes -- delete all user data" with the Power key.
- When Recovery Mode appears select "reboot system now" by using the Power button.
