When inside the car with doors closed or open pushing the rocker door lock unlock switch on either door,to the lock position will not actuate the locking mechinism. Under the same conditions though when pushing the rocker switch to the unlock position the unlock mechanism will actuate.
I tried the DIY service and repair manuals from a website and it actually
helped me repair transmission problem in my ford explorer. it wont move forward or reverse, engine is good both solenoids for forward and reverse work.
I don't have much technical knowledge but I just followed it step-wise, and works perfect! got it from www.reliable-store.com
SOURCE: Center Differential Lock Stuck
Yes it will, once no power is going to it it should or it could remain locked as well Give it a try . But you should have a look at the relay
1 2
3 4
that is what the pins should look lik 1 - 4 should power it
try grounding pins 1 - 4 this should lick or unlock the diff..
SOURCE: 1994 Lexus LS 400 Valet Lock Stuck - Can't Open Trunk
you have to have a main key. you may be able to remove the panel and release that way. under dash. pull cable.
SOURCE: 2003 GS 300 driver side doors will not lock
if you turn the key twice it should unlock and lock all doors until you can figure out the remote/lock switch problem.sounds like a door lock actuator problem on drivers door.I would start there.
SOURCE: drivers door lock will lock but not unlock with
Your door lock actuator is malfunctioning.
Since yours is a coupe your going to have to unbolt the window from the regulator, remove the 2 10mms on the left side of the door and pull that side of the regulator out of the way. then there are 3 T30 to-rx by the door latch that you need to remove, a cable that you pull off that connects your exterior door handle to the lock actuator and unplug the actuator. Then you can shimmy it out. The door pin and cables that attaches to the inside door handle need to be switched over to the new one.
Also if you have front side airbags they have to come off, but remember DO NOT turn the key on while the air bag is unplugged or you will have an airbag light that will have to be cleared. Also don't have the key on while you plug the airbag in or it supposedly goes off in your face, or so im told.
SOURCE: lexus rx300 trunk won't open
push down on trunk slightly then unlock, when open lubricate locking mechanism, if rear seat folds check for Florissant handle to open
