SOURCE: my speedometer on my 2000 yamaha r6 doesnt work
broken cable if your style bike has that style system, the cable that attaches to the axle shired off, i"ve had that stripped out also before and had to replace it.
SOURCE: 1999 YZF-R6: Yamaha YZF-R6 1999 Clutch feels very stiff. Does t...
THE OPERATION OF THE CLUTH ON HIS MODEL IS OF CABLE TYPE, IF THE CLUTCH IS OPPERATING CORRECTLY THE 1ST THING TO CHECK WOULD BE THE CABLE, REMOVE THE CABLE YOU SHOULD BE ABLE TO PULL THE INNER WIRE SMOOTHLY TO AND FRO, IF YOU NEED TO USE ALOT OF EFORT TO DO THIS THEN YOU WILL NEED TO REPLACE THE CABLE,MAKING SURE YOU HAVE ADEQUIT FREE PLAY AT THE LEVER WHEN RE FITTED. OBSERVE THE ROUTE THE CABLE TAKES BEFORE REMOVAL AND REPLACE IN THE SAME WAY, YOU MAY ALSO TRY TO GET SOME LITE OIL DOWN THE CABLE, THOUGH I SUSPECT THIS WILL BE ALMOST INPOSSIBLE IF IT IS THIS TIGHT TO OPPERATE
SOURCE: 1999 Yamaha R6....At what temperature
The electric fan comes on at an indicated 215F degrees. The high temp warning comes on at 242F degrees. I think this model has had some trouble with the fan relays going bad. If you are having trouble with your engine getting hot, I'd recommend checking the fan relay first.
