It was purchased about 4 years ago, I believe. It has two hand-held games in a set. One is a math game, and the other is a spelling type game.
SOURCE: Can not get a game to play
I just got the Sonic game to play again. Unfortunately, I had to reset the Didj--i.e., erase all the contents, including "Jet Pack Heroes" and my son's profile. Basically, I had to reset it to factory settings.
So all the stuff we worked on is lost, but at least he can play Sonic.
I got the instructions here:
http://community.leapfrog.com/blog-entry/Bad-Christmas-Presents/Didj-Needs-Tune/580000606
And here are the instructions:
"Launch LeapFrog Connect
It didn't work exactly like this, but that's the command you want to use to reset it when connected to the computer via USB. You'll know when it's resetting--it takes a good 5-10 minutes and very clearly tells you that you're resetting.
Hope this helps!
SOURCE: My daughter has a Leapster 2 (pink) hand held
Remove the game cartridge, while holding down the button with the "?" turn the unit on. Then the screen should tell you to press the "A" to calibrate the stylus. Finish the calibration by touching the crosshair when it appears. After I did this everything was fine. Good luck ....thaks to Nicksdad who posted this response to a previous post. Worked for me...try it.
SOURCE: Board Game rules for 'Who wants to be a Millionaire' 2nd edition
contact the makers and ask them to send you a copy they should be able to do that dont know if they will charge
SOURCE: I need a replacement game manual for our Four way
I did find the rules for Countdown. They can be found at:
http://www.educationallearninggames.com/how-to-play-4_way_countdown-game-rules.asp
There is also an abbreviated rules description at:
http://www.educationallearninggames.com/4-way-spell-down.asp
Hope this helps you out.
Thanks
SOURCE: I need the instructions for
Go to my website www.toysofdiscovery.com and email me privately. I will email you the instructions for Money!Money! as you requested.
I guess it didn't show everything that I typed in. :) Sorry. The game is called "Unjumbled".
Any ideas?
