Hi it wont start up and keeps cpming on with error message "remove the incompatible memmory module in slot B"
this has only just started and nothing new has been stuck anywhere etc?
It's either the memory on the 2nd slot is faulty or loose, try to reseat the memory and check if you will get the same error message if it does then try to remove the said memory on your laptop and check if the error will message will disappear then you can already tell that the memory card on bay 2 or slot b needs replacement.
sorry to be a pian but where is slot B cant see a slot anywhere
When i eventually found out where the 2nd memory slot was i discovered you were totally correct.
I replaced the memory card and it is now all working fine
Many thanks
