SOURCE: my dryer model number MEDC400V heats up but the
There are 2 catches in the front corners about an inch in take a putty knife and push in to release the top. Also take out the 2 screws under the lint filter. Lift up the top. You should see the belt or not. Belt there pull on it to see if it isn't broke. Belt not there broken belt. To replace belt need to take of the front panel. 2 screws in the cabinet top corners. Take them out then front will come forward then you need to lift it up off some little catches on the bottom. Then you should be able to see where the belt goes.
Testimonial: "advice worked great to see the belt!"
