Open Internet Explorer and go to google. In the google search type in "eMachines Support". Go to the support site and look for drivers and downloads. Enter your computer's model and it will take you to the download site. Enter your operating system and select the Audio Driver for your operating system to Download and Install.
It sounds to me like your flash player installation is corrupted, in order to correct this you will need to uninstall the program and reinstall it again.
Go to Start -> Control Panel -> Programs
Proceed to click on Adobe Flash Player, then uninstall. Follow the prompts that come up and uninstall flash player. Your computer will most likely need to reboot, if so go ahead and do that, if not then you can move onto the next step.
Go to Adobe's site here http://get.adobe.com/flashplayer/ and click on Download Now. A dialog box will open, download the file someplace easily accessed, such as your desktop. Certain web browsers may attempt to block the file from download, if this happens there should be a dialog box at the top of the website that will allow access for you to download from adobe's website, go ahead and click allow.
Once you have the file downloaded to your desktop, go ahead and double click the Adobe flash player icon and follow the subsequent dialog boxes, once flash is reinstalled you may once again have to restart your computer. Once this is all finished you should be able to play youtube videos again.
This menu displays music files saved in your phone and microSD card. 1.
From idle mode, press and hold the OK Key [OK] to unlock the keypad,
press the Left Soft Key [Menu], the Directional Key to select “Media
Gallery”, then slide out the QWERTY keyboard and press 1. My Sounds. 2.
Scroll through the downloaded or saved sounds to select the sound and
press the OK Key [PLAY] to listen to the highlighted sound. To erase
the selected sound, press the Left Soft Key [Erase], then press the
Right Soft Key [Yes]. 3. Press the Right Soft Key [Options] to choose
from the following: • Send by Picture Message: To send a MMS message. •
Send Online Album: To upload selected sound to sound online server. •
Send by Bluetooth: To send selected sound to another Bluetooth device.
• Set As: Assigns the selected sound for specific tasks (Ringtone,
Contact ID, Alert Tone). • Rename: Rename the selected sound. •
Lock/Unlock: Select to lock or unlock the selected sound. • Move: To
move the sound to another location. • Erase All: To erase all the sound
files in your phone. • File Info: Displays information about the
selected sound. Since you can’t Send or Move a DRM file, the Send/Move
options will not appear when working with these type of files. With
microSD card inserted, you can browse all folders and sound files saved
in the microSD card by searching the Back folder . indicates that
current file is stored in the external memory. indicates that current
file is stored in the phone memory. indicates that you have sub
directory for the current folder. Hope this helps, let me know if I can help you with anything else. JimmyC
You can go online from a different computer and go into HP website :
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=&cc=us&lang=&product=3239117&#
onece you have downloaded the drivers put it into a flash drive provided u have enough space in the flash drive.
Install the drivers on your computer.
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first.On most models, restart is done by holding the power button in for 15 seconds or longer.Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced. Download the Sansa Recovery Tool from the Sansa website. Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything. Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp If these fail, then: Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard. If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version). You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer. -Tha Mp3 Doctor
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced. Download the Sansa Recovery Tool from the Sansa website. Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything. Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to the Sandisk website and click "Firmware Updater" to find out.
Have you tried erasing old pix and text messages? If you check your phones available memory, and you have a lot of pix etc you can get a micro sd card and move your pix and videos to it. You check memory by going into menu, then se1ttings/tools, then phone info , other information usually...Good Luck
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced. Download the Sansa Recovery Tool from the Sansa website. Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything. Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp If these fail, then: Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard. If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version). You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer. -Tha Mp3 Doctor
Here is the download page for the Dimension 3000 (Windows XP): http://support.dell.com/support/downloads/devices.aspx?c=us&l=en&s=gen&SystemID=DIM_CEL_3000&os=WW1&osl=EN
Go to the audio driver page and assuming you have the built-in audio card this should take care of you.
If you by chance have some other operating system here is the link that will allow you to select the correct one. http://support.dell.com/support/downloads/index.aspx?
