Exercise & Fitness Logo
Anonymous Posted on Mar 08, 2012
Hello, I need a circuit board for Precor 956i, international model (230v).
The power conversion an motor control unit is blown. Where can purchase a new unit. It must operate with 230v.
ernesto cuadra
Level 3:
Top Expert:
  • Master 12,223 Answers
  • Posted on Mar 10, 2012
ernesto cuadra
Master
Level 3:
Top Expert:
Answers
12223
Questions
0
Helped
4081309
Points
34431
Dear Sir:
You can go www.fitnessrepairparts.com + www.treadmilldoctor.com +www.treadmillpartszone.com
sincerely. God bless you.
ernesto cuadra
managua, nicaragua. c.a
1helpful
What does error 21 mean?
Precor Error Code 21 Error Code: 21 Manufacturer: Precor
Model: All Models
Error Description: Error 21, Too many Consecutive Power Requests- The error 21 observes a treadmill's power bit reading when the treadmill was operating at speeds above 1 mph. Power bits indicate the relative time that the motor controller drive circuit is turned on. Power bits is an indication of the amount of power the load is demanding from the motor controller. Error 21 indicates that at a speed greater than 1 mph, an excessive amount of power is being demanded from the motor controller. Possible Reason:
  1. A badly worn deck and/or running belt can cause the error to appear when the unit is in use.
  2. Badly worn drive motor brushes may not be making proper contact with the drive motor commutator causing the error to occur when the unit is in use. The unit may also slow down or become sluggish when the load or speed is increased.
  3. A jumper may be required on the lower PCA if installed into a 120 VAC (Version 2) treadmill.
  4. A leaky or shorted drive motor filter capacitor (on units equipped with SCR motor controller) could increase the current demand enough to cause the error.
  5. A leaky or shorted drive motor inductor (on units equipped with SCR motor controller) could increase the current demand enough to cause the error.
  6. The high power demand is caused by a shorted or de-magnetized drive motor.
Recommended Action:
  1. Determine the amount of AC input current being drawn by the unit under no load and loaded conditions using a clamp on AC ammeter. The current displayed can be used to determine the condition of the deck and/or running belt. These same readings should be taken on a like unit, in good operating condition with a know good deck and running belt. The readings from the unit in good operationg condition can be used as the benchmark. Compare readings and replace* the deck and/or running belt if necessary. *Some units have a reversible deck. Be sure if the deck is being flipped or replaced, a new belt is installed on the new deck surface.*
  2. Inspect and repalce both drive motor brushes if necessary.
  3. Inspect the lower PCA (if unit is 120 VAC/ Version 2) for jumper. If jumper is not installed, error typically appears between 7 mph & 8 mph. Install jumper if necessary. CAUTION - DO NOT install jumper if unit is 240 VAC. Installing the jumper on a 240 VAC unit will casue the lower PCA to fail.
  4. Measure the AC input current without a load using a clamp on AC ammeter. Electrically isolate the filter capacitor from the drive motor circuit. The drive motor leads need be kept intact so the drive motor will operate with the filter capacitor removed from the circuit. Re-measure the no load AC input. If the AC input current is significantly lower, replace the filter capacitor.
  5. Measure the AC input current without a load using a clamp on AC ammeter. Electrically isolate the inductor from the drive motor circuit. The drive motor leads need be kept intact so the drive motor will operate with the inductor removed from the circuit. Re-measure the no load AC input. If the AC input current is significantly lower, replace the inductor.
  6. Swap the existing drive motor with a known good drive motor.
Precor Treadmill C956 error 21
Model: All Models
Recommended Action:
Precor error 20
Precor Error Code 20 Error Code: 20 Manufacturer: Precor
Model: All Models
Error Description: Error 20, Too many Maximum Power Requests in 1 Second - The error 20 observes a treadmill's power bit reading when the treadmill was operating at speeds of 1 mph or less. Power bits indicate the relative time that the motor controller drive circuit is turned on. Power bits is an indication of the amount of power the load is demanding from the motor controller. Error 20 indicates that at a speed of 1 mile per hour or less, an excessive amount of power is being demanded from the motor controller for an excessive length of time. Possible Reason:
  1. Starting the running belt under a very heavy load can cause the error 20 to appear.
    1. The user (especially a heavier user) is standing on the running belt as they start the belt into motion.
  2. A badly worn deck and/or running belt can cause the error to appear when the user steps onto the belt.
  3. Badly worn drive motor brushes may not be making proper contact with the drive motor commutator causing the error to occur when the user steps onto the running belt. The unit may also slow down or become sluggish when the user steps onto the running belt.
Recommended Action:
  1. Instruct the user to straddle the running belt while starting the treadmill at a low speed, such as 1mph or less, and then step onto the running belt.
  2. Determine the amount of AC input current being drawn by the unit under no load and loaded conditions using a clamp on AC ammeter. The current displayed can be used to determine the condition of the deck and/or running belt. These same readings should be taken on a like unit, in good operating condition with a known good deck and running belt. The readings from the unit in good operationg condition can be used as the benchmark. Compare readings and replace* the deck and/or running belt if necessary. *Some units have a reversible deck. Be sure if the deck is being flipped or replaced, a new belt is installed on the new deck surface.*
  3. Inspect and repalce both drive motor brushes if necessary.
Precor Error Code 20 20 Too Many Maximum Power Request in 1 Sec
Precor c966i error 20
Model: All Models
Recommended Action:
Precor 9.21s. Get ERR 21 message. Stopped Working
Model: All Models
Recommended Action:
Power keeps cutting out when clients are running on it.
When a running belt has excessive wear, it creates a lot of friction which causes the drive motor to work harder. When the drive motor works harder it will start overheating. If the belt is not lubricated periodically, it will ruin the deck, the drive motor, and cause other electrical problems such as tripping the breaker [after a while, the circuit breaker on the treadmill will need to be replaced.
It is suggested to lubricate the belt every month. At this point, you may need to replace both your deck and your running belt.
With your model and serial number, you can visit our website and view the products we have available for your particular machine.
Precor Parts for 952i 954 954i 956 956i Treadmills SPORTSMITH net
My Precor 956 keeps shutting off. Originally had error 21. As a result I gave the treadmill it's own outlet not sharing power with anything else. It now just cuts right out. It is a refurbished treadmill,...
Model: All Models
Recommended Action:
Top Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
john h
ADMIN Andrew
ADMIN Andrew
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
