The tv lost picture, audio was ok. turned tv off for a minute. turned it back on,a smaller dark picture appeared,but in 20 seconds tv went completely dead . could use a schematic
-   I've got a 27 inch and my problem is similar, with one exception: I can't get a picture on any of the VIDEO inputs, but do have normal TV as far as I can tell? Are they on two separate cards? If so, does it sound like I lost the card and is it worth replacing?-   lisfan
video card went out in the tv. You are saying you need a schematic. Be real careful getting into tvs. They have very large capacitating capacitators in them that can electrocute you. You need to take it to a repair specialist and have them run a check on it. Sounds like the video card to me though.
I recently installed a replacement lamp in my 2006 Mitsubishi DLP TV (WD-62627 model)& i...
(More)
I recently installed a replacement lamp in my 2006 Mitsubishi DLP TV (WD-62627 model)& i notice the picture is now slanted downward to the right; has anyone experienced this issue?
when the tv is on is blinks all the time. it started every once in a while, but now it's all the...
(More)
when the tv is on is blinks all the time. it started every once in a while, but now it's all the time.
Hi I have an Advent television that when I turn on, it seems like it is about to start for a few...
(More)
Hi I have an Advent television that when I turn on, it seems like it is about to start for a few seconds then immediately turns off.
Also, when I attempt to turn it on, a light in a different outlet turns on as well! So I don't know if it is from crappy electrical installation or just the TV causing this.
Thanks.
TV just stopped working. Pulled the power board a few months ago and rememberunsoldering a wire from...
(More)
TV just stopped working. Pulled the power board a few months ago and rememberunsoldering a wire from it. We bought a refurbished power board and I can't remember where the wire was soldered
