Heating & Cooling Logo
Anonymous Posted on Oct 31, 2008
Zarvik electric storage heater systems
I have this system but i dont know how to operate it. it has two switches next to each heater one unmarked and one marked off peak. each heater has its own room stat and the system has a timer which is supposed to control all the heaters.the problem is that the heaters seem to come on regardless of the timer.
can anyone tell me how to operate this system
1 Related Answer
Paul Carew
  • 3808 Answers
  • Posted on Jan 10, 2010
SOURCE: Need operating instructions for Zarvik storage heating system
zarvik heating ltd
81 station road marlow bucks sl7 1ns
hope this helps you should find there number in the yellow pages
Fuse for the alarm system
Here is the full list of fuses for you! and for the car.
Fuses on E-box, on left in Engine Compartment
Fuse 1 - Not assigned
Fuse 2 - 10/15A - Engine control unit
Fuse 3 - 5A - Radiator fan control unit
Fuse 4 - 5/10/15A - Lambda probe heater,
Lambda probe 1 heater after
catalytic converter
Fuse 5 - 10A, 20A - Lambda probe heater1,
catalytic converter,
Fuel system diagnostic pump,
Charge pressure control solenoid
valve,
Exhaust gas recirculation cooler
change-over valve,
Crankcase breather heater element,
Vacuum pump for brakes
Fuse 6 - 5A, 10A,15A - Fuel system diagnostic pump,
Throttle valve module,
Activated charcoal filter system
solenoid valve 1,
Continued coolant circulation pump,
Auxiliary air heater heating element
Fuse 7 - 20A, 5A - Ignition transformer,
Fuel pressure regulating valve,
Fuel metering valve
Fuse 8 - 10A - Throttle valve module,
solenoid valve 1
Fuse 9 - 5A - Automatic glow period control unit,
Electric fuel pump 2 relay,
Fuel pump relay
Fuse 10 - 5A - Speedometer sender,
Brake light switch
Fuse 11 - Not assigned
Fuse 12 - 5A - Coolant circulation pump
Fuse 13 - 5A - Water pump
Fuse 14 - 5A - Engine control unit
Fuse 15 - 30A - Voltage stabiliser
Fuse 16 - 30A - ABS control unit
Fuse 17 - 30A - Automatic gearbox control unit
Fuse 18 - 20A - Automatic gearbox control unit
Fuse 19 - 1A - Onboard supply control unit
Fuse 20 - 30A - Onboard supply control unit (AW0)
Automatic intermittent wash and
wipe relay (AW1)
Fuse 21 - 50A - Secondary air pump motor
Fuse 22 - Not assigned
Fuse 23 - 40A - ABS control unit
Fuse 24 - 50A - Trailer detector control unit
Fuse 25 - 50A - Terminal 15 voltage supply relay 2
Fuse 26 - 60A - Automatic glow period control unit
Fuse 27 - 60A - Radiator fan
Fuse 28 - 40A - Onboard supply control unit (AW1)
Fuse 29 - 40A - Onboard supply control unit (AW1)
Fuse 30 - 50A - Terminal 75 voltage supply relay 1
Fuse 31 - 30A - Amplifier
Fuse 32 - Not assigned
Fuse assignment - Interior Fuse Panel
Fuse 1 - Not used
Fuse 2 - 5A - Electronic steering column lock control module
Fuse 3 - 10A - Instrument cluster control module
Fuse 4 - Not used
Fuse 5 - Not used
Fuse 6 - 10A - Vehicle electrical system control module,
Interior ceiling lights,
Tail lights
Fuse 7 - 5A - Fog lamp relay,
Instrument panel and switch illumination dimmer switch,
License plate lamps,
Fuse 8 - 7.5A - Windshield and headlamp washer pump switch,
Windshield washer pump
Fuse 9 - 5A - Airbag control module
Fuse 10 - 10A - Right steering column switch
Fuse 11 - Not used
Fuse 12 - Not used
Fuse 13 - 5A - Automatic dimming interior rearview mirror,
Light recognition sensor,
Parking aid control module,
Air quality sensor,
High pressure sensor,
Climatronic control unit,
Tire pressure monitoring button,
Back-up lamp switch,
Left washer nozzle heater,
Right washer nozzle heater,
28-pin connector
Fuse 14 4- 10A - Left steering column switch,
ABS control module,
Light switch,
Airbag spiral spring/return spring with slip ring,
Fuel pump control module,
Data bus on board diagnostic interface
Fuse 15 - 10A - 16-pin connector (diagnostic connector),
Headlamp range control adjuster,
Auxiliary heater operation relay,
Mass airflow sensor,
Positive crankcase ventilation heating element,
Left front headlamp,
Left headlamp beam adjustment motor,
Right front headlamp,
Right headlamp beam adjustment motor,
Fuse 16 - 10A - Engine control module
Fuse 17 - Not used
Fuse 18 - 15A - Left front headlamp
Fuse 19 - 15A - Right front headlamp
Fuse 20 - 10A - Automatic transmission control module,
Selector lever sensor system control module,
Tiptronic switch,
Ignition/starter switch
Fuse 21 - Not used
Fuse 22 - 10A - Ignition/starter switch,
Converter box,
Alarm horn,
Interior monitoring sensor,
Alarm horn relay,
Dual tone horn relay
Fuse 23 - 10A - Vehicle electrical system control module,
Light switch,
Rain/light recognition sensor,
Compass magnetic field sensor,
Fuse 24 - 10A - Vehicle electrical system control module,
Access/start authorization control module
Fuse 25 - 15A - Automatic transmission control module,
Multifunction transmission range switch
Fuse 26 - 15A - Brake system vacuum pump
Fuse 27 - Not used
Fuse 28 - 40A - Auxiliary heater operation relay
Fuse 29 - 1A - Vehicle electrical system control module,
Fuse 30 - 20A - Cigarette lighter,
12 V socket,
12 V socket 2,
Blocking diode
Fuse 31 - 30A - Light switch
Fuse 32 - 20A - Light switch
Fuse 33 - 40A - Heater/heat output switch,
Fresh air blower relay,
A/C control module,
Fresh air blower switch
Fuse 34 - 15A - Left front headlamp,
Fuse 35 - 10A - Steering column electronics control module,
Instrument cluster control module,
Signal horn activation,
Fuse 36 - 25A - Vehicle electrical system control module
Fuse 37 - 15A - Left front headlamp DRL
Fuse 38 - 15A - Right front headlamp DRL
Fuse 39 - 15A - Low beam relay
Fuse 40 - 15A - Towing recognition control module
Fuse 41 - 15A - Towing recognition control module
Fuse 42 - 20A - Towing recognition control module
Fuse 43 - 30A - Front passenger door control module
Fuse 44 - A25 - Rear window defogger relay,
Fuse 45 - 30A - Driver door control module,
Fuse 46 - 30A - Left rear door control module,
Right rear door control module
Fuse 47 - 15A - Fuel pump control module,
Fuel pump relay,
Fuel primer relay
Fuse 48 - 20A - Vehicle electrical system control module,
Fuse 49 - 20A - Climatronic control unit,
A/C control module
Fuse 50 - 30A - Front seat heating control module
Fuse 51 - 30A - Power sunroof control module
Fuse 52 - 20A - Dual tone horn relay
Fuse 53 - 15A - Front seat heating control module
Fuse 54 - 15A - Fog lamp relay
Fuse 55 - 20A - Light switch,
Fuse 56 - Not used
Fuse 57 - 15A - Radio,
Radio/navigation display unit control module
Fuse 58 - 1A, 30A - Telephone transceiver
DC/AC converter with socket, 12V-230V
Fuse 59 - 30A - Amplifier
Fuse 60 - 30A - Auxiliary heater control module
Hope this helps
--N
Water oozing from top of my Everhot electric storage system where there is a rubber stopper. Can I fix this myself?
1) Bradford White posts some Operation manuals, and troubleshoot guides for electric tankless units:
1-800-334-3393
http://www.bradfordwhite.com/documentation/residential/electric.asp
2) For gas:
http://www.bradfordwhite.com/documentation/residential/gas_tankless.asp
3) I do not know of a rubber stopper used for plumbing or tankless.
4) Call service technician.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Creda storage heater manual
I'm not a heating expert, but according to the information I could find, Economy 7 utilizes cheap electricty at night, during off-peak hours (7 hours) between midnight and 7AM. Economy 7 costs about 4p per unit compared to peak electricity, which is about 10 to 15p per unit. If you do not have Economy 7, you can request it FREE of charge from your electricity provider. You will either have one meter with two readings or two separate meters. A two tariff electric meter will record the electricity used during off peak times, so it can be billed, separately, at a lower rate. If you have two meters, one meter controls on peak daytime electricity and the other controls your night time economy 7 electricity.
I would need to know what model Creda heater you have installed in order to determine how energy efficient it may be. I also will need the model so I can determine operating instructions. If you need further assistance, please post back and let me know. I hope this helps.
The rear heater does not heat up when switch is on
Troubleshooting by Symptom Poor Heater System Performance
  1. Start the engine. Allow the engine to idle. Does the engine reach normal operating temperature? If yes, go to the next step. If no, go to step 8.
  2. Allow the engine to idle. Select the FLOOR mode. Select the minimum blower speed and the warmest temperature setting. Feel the temperature of the inlet and outlet heater hoses at the heater core. Does the inlet heater hose feel warmer than the outlet heater hose? If yes, go to step 6. If no, go to the next step.
  3. Install a thermometer into the center I/P PANEL air outlet. Secure a thermometer to the heater core outlet heater hose. Select the PANEL mode. Select the maximum blower speed. Select the warmest temperature setting. Record the temperature at the center I/P PANEL air outlet and at the heater core outlet heater hose. Are the two temperature readings about equal? If yes, go to the next step. If no, go to step 5.
  4. Inspect and repair the cowl, recirc door, and the HVAC module case for cold air leaks. If problems are found and repaired, go to step 9.
  5. Inspect the temperature door operation. Perform any necessary repairs. When repairs are made, go to step 9.
  6. Turn OFF the engine. Backflush the heater core. Start the engine. Select the FLOOR mode and the lowest blower speed. Select the warmest temperature setting. Feel the temperature of the inlet and outlet heater hoses at the heater core. Does the inlet heater hose feel warmer than the outlet heater hose? If yes, go to the next step. If no, go to step 9.
  7. Replace the heater core. When the repair is complete, go to step 9.
  8. Repair the low engine temperature concern. When the repair is complete, go to step 9.
  9. Operate the system in order to verify the repair. If the system operates properly, the repair is complete. If the heater still does not work properly, repeat the entire procedure.
Insufficient Defrosting
  1. Start the engine, select the DEFROST mode, and select the maximum blower speed. Does sufficient air flow from the defroster outlets? If yes, go to the next step. If there is insufficient airflow, go to step 9.
  2. Measure the engine operating temperature. Does the engine reach normal operating temperature? If yes, go to the next step. If the engine does not reach normal operating temperature, go to step 7.
  3. Select the minimum blower speed. Select the warmest temperature setting. Feel the temperature of the inlet and outlet heater hoses at the heater core. Does the inlet heater hose feel warmer than the outlet heater hose? If yes, go to step 10. If the hose temperature is not right, go to the next step.
  4. Test the operation of the A/C compressor clutch. Does the A/C compressor clutch engage? If yes, go to the next step. If the compressor clutch does not engage, go to step 6.
  5. Repair or replace the A/C compressor clutch. When the repair is complete, go to step 13.
  6. Repair the A/C compressor clutch concern and determine if the A/C system is operating within specifications. If yes, go to step 8. If no, go to step 11.
  7. Repair the low engine temperature concern. When the repair is complete, go to step 13.
  8. Inspect for correct operation of the recirculation door. If the door is operating correctly, go to step 13. If the door is not operating properly, go to step 12.
  9. Repair the air delivery concern. When the repair is complete, go to step 13.
  10. Repair the heating concern. When the repair is complete, go to step 13.
  11. Repair the A/C performance concern. When the repair is complete, go to step 13.
  12. Repair the recirculation door concern. When the repair is complete, go to step 13.
  13. Operate the system in order to verify the repair. If the system is operating properly, the procedure is complete. If the system is still not providing proper defrosting, repeat the entire test
. Noise from the HVAC Module
  1. Start the engine. Cycle through all blower speeds, A/C mode settings and temperature control settings. Determine the type of noise, whether it is a scraping, popping, ticking, clicking, chirping or groaning, or an air rush or whistle. Is a scrape or pop noise evident when selecting modes or temperature settings? If yes, go to step 5. If no, go to the next step.
  2. Is a tick/click, chirping, groaning or scraping noise present, but decreases as blower motor speed is decreased? If yes, go to step 5. If no, go to the next step.
  3. Is an air rush/whistle noise evident in all modes but not all temperature settings? If yes, go to step 5. If no, go to the next step.
  4. Is an air rush/whistle noise evident only in defrost or floor mode? If yes, go to step 5. If no, examine for other sounds, repeat step 1.
  5. Remove the I/P trim pad. When complete, go to the next step.
  6. Inspect the airflow doors for proper operation and the ducts for obstructions or foreign materials. Were any of these conditions found? If yes, go to step 9. If no, go to the next step.
  7. Inspect the mode and temperature doors and seals for warping or cracking. Are the doors in normal condition? If yes, go to step 9. If no, go to the next step.
  8. Replace the appropriate door and/or seals. When the repair is complete, go to step 10.
  9. Remove any obstructions or foreign material found. When the repair is complete, go to step 10.
  10. Install the I/P trim pad. When complete, go to the next step.
  11. Operate the system to verify the repair. If system operates without noise, the repair is complete. If noise still exists, repeat the entire procedure.
1helpful
zarvik heating ltd
2helpful
I have the same problem with my windstar blower is fine but is coming cold air but no heat i dont know what to do can any one show me how to fix it thnx
First, feel the heater hoses going into the firewall under the hood. If they are hot, then you have hot engine coolant going into the heater core. If they are not hot, then you either have a bad thermostat or you are very low on engine coolant.
Next you need air flowing through the heater core so it can come out heated through your vents. If the iar is flowing somewhere else, your temp blend door is not moving because the bend door motor is bad or your temp knob on your heater controls is bad. The blend door motor is an electric motor.
Air Flow Control
Air flow control is accomplished in the following manner:
  • Primary control is through the function selector knob , mounted on the heater function selector switch, which is part of the heater control .
  • The function selector knob has the following positions: OFF, PANEL, PANEL/FLOOR, FLOOR, FLOOR/DEFROST and DEFROST.
  • The heater function selector switch combines a vacuum selector valve with an internal electrical switch.
  • The vacuum selector valve directs source vacuum to various vacuum control motors (18A318) . Refer to the System Airflow Schematic and Vacuum Control Charts.
  • An internal single-pole electrical switch is also controlled by the selector. The switch controls the electrical supply to the heater blower motor switch (18578) .
  • The position of the function selector knob determines the manner in which the system will operate.
  • Each position of the function selector knob is detented for positive engagement.
Temperature Control
The temperature control operates in the following manner:
  • Temperature control of the heater system is determined by the position of the temperature control knob (between COOL-BLUE and WARM-RED) of the heater control .
  • This control knob is connected to a potentiometer mounted in the heater control . This potentiometer is electrically connected to the electric blend door actuator that operates the A/C air temperature control door.
  • Movement of the control knob from COOL (Blue) to WARM (Red) causes a corresponding movement on the air temperature control door and determines the temperature that the system will maintain.
System uses a reheat method to provide conditioned air to the passenger compartment.
  • All airflow from the blower motor (18527) passes through the A/C evaporator housing .
  • Temperature is then regulated by reheating a portion of the air and blending it with the remaining cool air to the desired temperature.
  • Temperature blending is varied by the air temperature control door, which regulates the amount of air that flows through and/or around the heater core (18476) , where it is then mixed and distributed.
inside you plenum box:
Slimline storage heaters with no switch to turn on/off - how do you turn them on? have taken off the front panel but can see no switch/override - the electric cable comes straight from the wall into the...
The principle of electric storage heaters is that they take in electricity at night through a central time switch (normally owned by the electricity supply company and usually not controllable by the user).
There should then be a main switch/ fuse box to control the heater circiuts, check for such a box and that it is switched on (This would normally be sited near the electricity meter).
There should be an isolator switch next to each heater but from what you say this is not the case.
There should be some controls on each storage heater marked INPUT with a dial from 1 to 6 or similar then another marked OUTPUT or BOOST.
When you have ascertained the fuse box is on and the heater controls are set to maximum you then have to wait overnight for the heaters to warm up.
13helpful
5answers
Heater blows cold air
the electric motor that open the heat door looses electrical connection there by the door stays on cold / it is located under the a/c heater assembly / which requires removing the whole dash and heater assy// also bleed all air out of coolant system
there are three doors / 1/ a/c heat 2/ mode /defors 3/ recurculation [email protected]
Top Heating & Cooling Experts
Paul Carew
john h
