4GB ram intel pentium E5400 2.7GHZ
SOURCE: 3.25 Gb usable Ram for 4Gb installed ram
This is often a strange thing. Sometimes it is related to your video card using part of the address space which makes part of your RAM unusable. Although I though 64 bit os's solved that problem. Sometimes it is related to the 1kb = 1024 bytes and not 1000 bytes.
The good part is you are not limited to 4Gb because you have a 64 bit os.
It is also really hard to tell how much memory is actually free because Windows 7 add another level of bull to things where it tries to preemptively load things into ram ahead of time.
4Gb is still a lot of ram so I wouldn't worry to much about it unless you are having problems. You will probably be stuck up against a CPU or I/O bottle neck before you run out of ram.
SOURCE: just built 2 computers all the same parts both
yo...........3 beeps at switch on is memory problem.........take out each stick......
check for dust ..reseat 1 stick at a time.........
try other sticks if you have them....
cheers
SOURCE: RAM for Intel E210882 mboard
This are the compatible RAM for this mobo :Support for DDR 400, DDR 333, and DDR 266 and you can upgrade up to 4GIG or RAM this is the complete specs for this mobo http://www.gearxs.com/gearxs/product_info.php?products_id=8076
Hope that helps..........
SOURCE: I have installed new DG41WV
I have the same problem few days ago and found my solution on Fixya Expert Sources website. Here you will get all the top sources of your problem. All the sources of this site provided by top Fixya
Gurus. Have a good look at the sources of the page. Go through
the sources to find your solution. Hope it will help.
View Count:2
SOURCE: -motherboard asrock 775vm800 -cpu intel pentium
No, it doesn't, see here
http://www.via.com.tw/en/products/chipsets/p4-series/comparison_p4-series.jsp
Testimonial: "thx"
