SOURCE: Hummingbird Fishfinder model 535
The Depth & temp come from two different sensors. Check your coax cable to the transducer (the lager oval piece), the connector, and the transducer for cracks /breaks in insulation. Good luck.
SOURCE: wire on depth finder has been piched, can tou
Yes, you can. I have done it several times. Keep the separated wires fairly short. You can pick the braided (shield) wire apart with a pin or such.
SOURCE: My furuno depth finder gives me crazy depth
Turbulence on the transducer is almost certain. If transom mounted, **** it slightly deeper aft and ensure that the leading edge is not exposed. If through hull, call me 847-746-0100
SOURCE: My depth finder loses its depth reading at about
You need to set the transducer lower. When at speed, the hull of the ship raises up out of the water and hence your transducer is probably not deep enough at these times to give a proper reading.
SOURCE: my Furuno reads 3.5 feet
There is a keel offset or waterline offset that can be entered in the menus. Press "MENU" + go to "DRAFT", use right arrow to enter menu, change using up and down, the press "MENU" when done. Note that "DRAGHT" is on PAGE TWO(2)!! of the main menu. John 847-746-0100 technicalmarine.com
