-   Used my TRV250 4 days ago, packed it with luggage and flew back home, tried to turn it on and nothing responds. Even when I hook it up to the charger or use the back-up battery: nothing. ?-   yassolm
Mar 22, 2009
-   my VLz3U camera will not charge either. bought a new battery, had the adapter checked. the charge light will not come on, nor will it power on with the adapter plugged in, It does flash for a split second (internal light) but goes off right away. -   Guest
Mar 20, 2009
-   Haven't used the camera for about a year. Finally found a charger for the battery, verified batteries have voltage but camera still won't turn on.-   Guest
Jan 22, 2009
-   i accidently plugged the wrong charger to the camerea and i think it may of short circuited dos anyone know what exactly i did to my camerea? where can i repair it-   bennyhadcam
Sep 24, 2008
-   De repente ya no se enciende-   tonibilly
Check the output from the AC Adapter first. If no good, battery not charging/dead so nothing works. If good, camera needs service - could be anything. There is probably at least one surface mount fuse.
i checked the ac adapter you know the square thingy that connects to the other ac cable, well came to find out that the other cable wasn't all the way plugged in the square thing, so next time someone has a problem with the power make sure everything is plugged in right. thanx
Gets no power from battery pack or ac source. I have a Panasonic vdr-d100 DVD camcorder...Plaese help!
Was this helpful?
Yes
No
Solution #4
posted on May 07, 2008
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Theres hundreds of these models on ebay, all new and all faulty!!! Iv had a couple all boxed never used and dont power up! Must be a faulty batch not worth repairing!
Solution #5
posted on Feb 21, 2008
Guest
Rank: Apprentice
Rating: 0%, 0 votes
I Have Had Mine Serviced Just received it back.. Hmmm its charged the new cashback battery in 60 minutes light is off so same problem.....The batteries are probably killing my cameras charger. My camera is 8 to 9 weeks old now
non picture is coming through, but sound is ok, and playing something dat i recorded before...
(More)
NON PICTURE IS COMING THROUGH, BUT SOUND IS OK, AND PLAYING SOMETHING DAT I RECORDED BEFORE EVERYTHING IS OK
Canon zr60 has stopped showing view in LCD screen during record. Play works fine. In the past I...
(More)
Canon zr60 has stopped showing view in LCD screen during record. Play works fine. In the past I have fooled around for awhile and it somehow started working but not anymore.
There is no sound on playback when capturing video with my camcorder. I'm assuming the camera isn't...
(More)
There is no sound on playback when capturing video with my camcorder. I'm assuming the camera isn't capturing it at all. I've tried to check this by connecting A/V cables to another source and still no sound at playback. I am going to try cleaning the heads to see if this works. Thanks Jesse
haven't used the cam in years. plugged it so it can get it to charge but the charge indicator light won't turn on and the cam won't turn on either so I thought the battery could juz be dead. So, I bought a new battery pack and the round battery. Still won't turn on after I connect the charger. Charge indicator light still won't turn on. I don't know what else could be the problem.
Comment by Guest, posted on Aug 04, 2008
Have used the Cam till all the power exhausted, then I tried to charge it using the adapter. But the Camcoder is not charging.
I have an Aiptek Pocket Cam and cannot get it to power on. I have put in two new sets of batteries so I know that is not the problem. The green light does come on when I have it connected to the computer and it will show no music files at that time. Any suggestions.
I do not have battery charger, only ac adapter and new batteries still wont power camera. I am able to power camera through wall adapter but the wall power adapter will not charge battery through camera.
I have the same power supply problem. The camera will not turn on with the charged battery or the ac adapter. I live in a remote area is there a way for me to check for a bad fuse? Or what else can you suggest?
Comment by Guest, posted on Dec 24, 2007
I have the same problem, the power indicator light will not turn on with the charged battery or the ac adapter. i live in a remote area, is there a way i can check if a fuse is bad, or what would u recommend?
Dave dropc_riff@hotmail.com
