20 Most Recent Canon ZR830 Mini DV Digital Camcorder Questions & Answers
You can download a user manual here. Your problem, however, does not seem to be related to the camera, but to the SD card. Take the card out and look along the edge for a small 'switch'. This switch will have a 'locked' and an 'unlocked' position. Make sure it is 'unlocked'. If you still get the advisory, try another SD card. (Sometimes those little 'switches' fail.)
Canon ZR830 Mini... | Answered on Oct 03, 2018
there is a little switch on the side up and try then it will work
Canon ZR830 Mini... | Answered on Nov 20, 2011
you have to record the video to an sd card and then download it to your computer thats the only way
Cemera
Canon ZR830 Mini... | Answered on Aug 13, 2011
You need one of these http://www.pixmania.ie/ie/uk/5845787/art/noname/recorder-easy-usb-video-g.html
Canon ZR830 Mini... | Answered on Apr 29, 2011
This is usually caused by a defective CCD image sensor and can be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Canon ZR830 Mini... | Answered on Feb 11, 2011
This is usually caused by a failed component in the power circuit within the camera and can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired qualified service technician.
Canon ZR830 Mini... | Answered on Dec 17, 2010
This is usually caused by an oxidized or defective Audio/Video drum. Try running a cleaning tape through the camera. If this does not solve the problem the camera will need to be repaired qualified service technician.
Canon ZR830 Mini... | Answered on Nov 29, 2010
You cannot see review pictures though the viewfinder (peephole) or the lcd (screen)?
Let me know,so that we could proceed.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Canon ZR830 Mini... | Answered on Nov 11, 2010
This can be caused by several problems including the transmission gear in the tape mechanism not engaging properly or a defective clutch in the take-up spool and can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
Canon ZR830 Mini... | Answered on Nov 01, 2010
Canon ZR830 Mini... | Answered on Oct 18, 2010
You can find the step by step procedure from page 69 of the user manual of this unit , that you can get from this link. It has the detailed steps that you need to do for the transferring of files from the camera to your computer.
http://www.retrevo.com/support/Canon-ZR830-Camcorders-manual/id/918dj888/t/2/
Canon ZR830 Mini... | Answered on May 17, 2010
According to Microsoft, the ZR90 is compatible with Vista 32 and 64 bit:
https://www.microsoft.com/windows/compatibility/Details.aspx?type=Hardware&p=ZR90&v=Canon&uid=ZR90&pf=3&pi=7&c=Cameras%20%26%20Photo&sc=Camcorders&os=32-bit
Try clicking on "free download required" on the above page; it's probably the driver update.
Canon ZR830 Mini... | Answered on Oct 06, 2009
If there is no problem when you play back on a different camera or computer, then the fault concerns LCD ribbon cable or lcd controller circuit on main pcb.
If the recorded image is also distorted on computer and different camcorder, then you have a faulty ccd sensor.
Also wiring problem and pcb fault sometimes can cause ditorted picture, in that case the problem is usually a kind of dirturbance and does not happen all the time.
Regards.
Canon ZR830 Mini... | Answered on Jun 24, 2009
Canon ZR830 Mini DV Digital Camcorder Logo
37 questions posted
Top Canon Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
View Most Popular
ZR Canon
  • ZR Canon
Most Popular Question
always says remove
  • Video Cameras
