If your computer came with a motherboard disc the sound drivers could be on it click start control panel administration tools computer management device manager scroll to sound video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to click start control panel sounds and audio volume advanced speakers make sure you have selected the (appropriate speakers) also audio you will find 3 drop down lists make sure you have the correct settings there
reinstall drivers
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
If this Answer goes some way towards helping
to resolve your Query, Problem or Fault, please take the time to Rate it. Doing
so helps Solution Providers, like me, better understand the needs and the point
of view of Askers, like you, and guides us in exploring the best ways to
provide the most comprehensive, useful and high quality Responses and Solutions
we can. If you need further help, please do not hesitate to post another
Question or add a Comment to this Question.
Thanks for using FixYa.
Connecting audio from TV
When connecting the audio output from your TV to this Home Theater Audio System, you will have the sound of the
TV output on all the speakers. It will enable you to enjoy the multi-channel surround sound capabilities.
Use an audio cable (red/white - not supplied) to connect the TV IN jacks on this DVD system to the AUDIO OUT
jacks on the TV. To listen to the sound, press TV on the remote control as the sound source that you want to play.
Connecting audio from an audio/video device
This DVD system provides analog and digital audio connection. You can connect the audio output from an
audio/video device (e.g. VCR, Cable/Satellite Box) to this Home Theater Audio System in order to enjoy the
Use an audio cable (red/white - not supplied) to connect the AUX IN jacks on this DVD system to the AUDIO OUT
jacks on the connected device. To listen to the sound, press AUX/DI to select "AUX" as the sound source that
you want to play.
Or
Use a coaxial cable (not supplied) to connect the DIGITAL IN jack on this DVD system to the DIGITAL OUT jack on
the connected device. To listen to the sound, press AUX/DI to select "DI" as the sound source that you want to play.
Please leave feedback
Cheers
Andy
Sound problem gives no useful information to help you. Please describe the problem in detail.
