Philips HTS3450 System Logo
Posted on Apr 27, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Why? no sound from the speskers at all. - Philips HTS3450 System
Anonymous
Level 3:
  • Master 910 Answers
  • Posted on Apr 27, 2011
Anonymous
Master
Level 3:
Answers
910
Questions
Helped
306734
Points
2616
There are a few things that could cause no sound and although some are obvious I'll got through them all..
1) Sound is on Minimum
2) Sound is Muted
3) No Power to Subwoofer
4) Speakers connected Incorrectly or Faulty
5) No AUDIO IN connections to TV-IN or AUX-IN
6) Incorrect Input Source is Selected (See Below)
Connecting audio from TV
When connecting the audio output from your TV to this Home Theater Audio System, you will have the sound of the
TV output on all the speakers. It will enable you to enjoy the multi-channel surround sound capabilities.
Use an audio cable (red/white - not supplied) to connect the TV IN jacks on this DVD system to the AUDIO OUT
jacks on the TV. To listen to the sound, press TV on the remote control as the sound source that you want to play.
Connecting audio from an audio/video device
This DVD system provides analog and digital audio connection. You can connect the audio output from an
audio/video device (e.g. VCR, Cable/Satellite Box) to this Home Theater Audio System in order to enjoy the
Use an audio cable (red/white - not supplied) to connect the AUX IN jacks on this DVD system to the AUDIO OUT
jacks on the connected device. To listen to the sound, press AUX/DI to select "AUX" as the sound source that
you want to play.
Or
Use a coaxial cable (not supplied) to connect the DIGITAL IN jack on this DVD system to the DIGITAL OUT jack on
the connected device. To listen to the sound, press AUX/DI to select "DI" as the sound source that you want to play.
Please leave feedback
Cheers
Andy
Sound out on 2004 sony flat screen is there a reset
check the audio output on the audio board check voltage very low
I want my cobra 29 to sound like a big radio can i do this without buying an echo board
The radio is equiped with an spesker exteneion jax at tje rear.Simlly plug in an approiate speaker! !
Humming sound from left spesker
sounds like the cartridge lead on the left side of your cartridge is coming off. Or the ground cable of your tone arm or your table is loose.
My labtop sounds i means spesker is not working
1st you check sound card driver installed in the laptop. If it is install then problem in speaker.
T6100 creative 5.1 speskers
Any computer or music shop should have those jacks handy.
1helpful
When recording soud nothing from the speskers
go to your recording properties and see mic is selected and the volume levels are not muted. Also is it a normal mic or usb mic?
Speskers not working
check in my computer properties device manger .
check that sound driver install correctly.
ther eis not any yellow exlamanATION Mrk.
Sub's not playing loud any more
you need to be shure of that,becarefull of hearing loss due to high spl also these speskers are capable of playing although the coils are burnt resulting in poor performance.
Top Philips Audio Players & Recorders Experts
 Grubhead
Grubhead
SmartAviator
SmartAviator
ZJ Limited
ZJ Limited
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
