Windows 7 64bit driver for LBP-2460. It is a PCL5e printer with duplexer, 2 paper trays and handles 11x17 paper. I had this runing under Windows 7 32bit. I used a driver or another canon printer. Worked...
Try this:
Connect the printer to the PC and turn it on. Windows might start it's driver install thing. Tell it to search online for drivers, it might find it/them. If that doesn't even happen, go to Device Manager to see if the printer is there. If so, right click on it, choose Properties. Then, click on Update Driver, and tell it to search online. Also, Windows Update might find updates for that printer in the optional updates tab.
Also, if you happen to have the original install CD, you could place it in the CD drive, tell it not to do anything. Then, access the disc from Windows Explorer or My Computer. Find the setup file, and make a shortcut for it. Then, right click on the shortcut, choose Properties. On the Compatibility tab, you could maybe tell the shortcut to run in XP SP3 mode or whatever.
Also, for Canon support, go here:
https://www.usa.canon.com/internet/portal/us/home/support/
Good luck.
