Looking for owners manual for craftsman exact-i-rip fence for tablesaw
SOURCE: On Craftsman tablesaw/model 137.248830, was
Did you check that the circuit breaker did not trip, and there is power at the plug you are using?
A long extension cord or low voltage will sometimes cause the breaker to trip.
SOURCE: crafstman radial arm saw owners manual model #113-29440
Go to this link and you'll be able to download the pdf file of the operating instructions for you saw.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
SOURCE: need a owners manual for a Sears/Craftsman 10inch
Go here:
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0803498.pdf
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Testimonial: "wow-- thanks a million! exactly what i was looking for. "
SOURCE: rip fence to saw blade alignment
I dont believe there are pictures, but what you need to do is move the fence to the blade, there are 2 10MM bolts on the backside that you need to loosen and then you can move the fence to square with the blade. Snug them down and move the fence and recheck let me know if you have anymore problems
SOURCE: I have a craftsman table saw model #113.298032. My
If you are using a thin kerf blade the blade may be flexing if you are ripping thick, or hard stock. If the saw has had a lot of use the motor bearings/bushings may be worn to the point of allowing the shaft to move horizontally. I also have to suggest the possibility that your fence may not be locking securely.
