Health & Beauty Logo
bonnie ramos Posted on Feb 12, 2012
Instructions for how to use a veridian digital thermometer
Digital ear thermometer
Betsey Lipps
Level 1:
  • Contributor 1 Answer
  • Posted on Sep 24, 2014
Betsey Lipps
Contributor
Level 1:
Answers
Questions
0
Helped
2947
Points
0
I just talked to customer service. You press and hold the scan button then press the memory button on the back. It switched immediately.
Anonymous
Level 1:
  • Posted on Jul 05, 2013
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
2947
Points
0
How do you change it to read Fehrenheit instead of Celsius?
Change from Celsius to fareinhight
While it's on, tap both mem and mode button at the same time. Unless you have big thumb, you might want to use your left and right to do this.
How do I change veridian 09-348 from celcius to Fahrenheit?
turn it on and then hold both the mode and mem button it should toggle after a second or so
How to use the Digital ear thermometer
Hello, Here is the website for the download of the users manual for this product: Product Support from Mabis DMI Healthcare
Change function
on the hand held unit there are 2 switched to the right and left one changes from F to C and the other is a volume switch.
How to change setting from celcisus to farenheit
hold the power button once its on until it beeps then push one of the other buttons to change
What does Er. 3 mean on veridian temple thermometer
Er.3 means the unit is sensing the ambient temperature (i.e., room temperature) is below or above the specified range needed for the unit to operate. If the unit has been inside at normal room temperatures, it probably means the unit is defective or otherwise broken. You can attend to reset by removing the batteries for at least two minutes then reinserting before attempting to use again. Repeated "Er.3" messages mean the unit is now garbage.
My son has your safety 1st Hospitals Choice Fever Light Ear Thermometer and he has lost the instructions. Can I download them somewhere? We need to know how to use the ear thermometer. Thank you
Go to http://www.safety1st.com/usa/eng/Products/Child-Care/Thermometers/?start=0 and find your thermometer. Click on the picture, towards the bottom there is a section you can click on called instructions. Then it will bring up a new menu it will ask you to enter your product type, model, and manufacture date and you can download the instructions from there. I hope this helps.
Jun 21, 2011 • Baby Care
I need a instrution manual for a ear themoniter model no ET1200
Hi.
  • 1 Consider that most digital thermometers take a temperature in less than 30 seconds, quickening the temperature-taking process for squirmy children.
  • 2 Read the thermometer's instructions carefully. Never throw the instructions away. Keep them near your digital thermometer.
  • 3 Wipe the thermometer probe with a soapy washcloth or a tissue dabbed in isopropyl alcohol or put on a clean probe, depending on your brand of thermometer.
  • 4 Turn the thermometer on.
  • 5 Use a gentle rocking motion as you insert the thermometer into the ear canal or rectum. Never push or cram the probe into the body. Forcing it causes pain, especially if there is swelling in the ear canal or rectum.
  • 6 Listen for the beep.
  • 7 Remove the thermometer.
  • 8 Read the thermometer. If you see "ERR," you did not get good contact with the ear canal or rectum, and will need to take the temperature again.
  • 9 Use the chart insert that comes with your thermometer to see what your normal reading should be.
  • 10 Clean your thermometer probe with a soapy washcloth and/or isopropyl alcohol before storing.
  • 0helpful
    User instructions for the Omron thermometer
    send me ur details supose i will get user book i will send u mail. [email protected]
    pls send product details also
    Top Health & Beauty Experts
    Rob Hill
    Rob Hill
    ADMIN Andrew
    ADMIN Andrew
    ADMIN Eric
    ADMIN Eric
    Are you a Health and Beauty Expert? Answer questions, earn points and help others
