I am not able to make video from my cell phone. I can shoot 2-3 seconds video from it after than it stops automatically. Kindly help.
Open camera >>Video mode>> setting>> and select the memory to be stored to Memory card.Move all the data which is stored in phone memory to memory card.But I'm not sure that there is a setting to extent the duration of video recording.I've mention and advice that this may help you.Thanks for visiting fixya
SOURCE: NOKIA N72 RECORDING TROUBLE SHOOT
hi sir..
please go to tools> settings>phone> general> restore factory setting> it will ask for passward. eneral passward is 12345 or ur personal security code. it will restart. see now it work's.. don't forget to fix.
SOURCE: camera automatic off
This is actually hardware problem.
When u open the lens cover behind,there is a small button which is pressed.The camera works until the button is pressed and goes off when released.you just tightly press your lens cover.or try consulting at service centres..
SOURCE: nokia n72 phone memory restoration problem
Go to Contacts->Settings and there you will find an opportunity to set what all you want to see when a call comes or when you are browsing the Contact List.
SOURCE: How i can scan phone memory of my cell nokia N72
You problem is not related to scanning the phone memory or anything about memory. First of all reset the phone to default settings, to do this, go to Settings in the Menu - Press Up key once and select Restore Factory - Ok - enter this code 12345 and provide positive input and the phone will restart automatically, now check whether it's working or not. If you aren't familiar with the N70 mobile, it would be difficult but you will learn new things. If you are still having the same problem, the problem is with the hardware, Ringer and the ********, and they are needed to be replaced. Good luck..
SOURCE: my cell phone nokia 5310
Hi.
Go to this page and download Nokia Suites for your PC:
http://europe.nokia.com/support/product-support/nokia-5310-xpressmusic/software
Install the software and the connect the phone to the PC by USB cable.
WARNING: Be sure to have the battery FULLY charged!!! Do NOT disconnect the phone until the update is finished!!!
Click on Software Updates:
If after the update the phone is still not working or if you can't connect the phone to the PC you just have to take it to service.
Achil
