Nokia N72 Cellular Phone Logo
Posted on Aug 31, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to set the recording length maximum in n72
I am using n72.. The recording time is set to 1 minute by default.
how to increase the recording length to maximum free space availabe in memory.. ie. how to maximize my recording time ...
Pl mail me
Thanks in advance
Anonymous
Level 3:
President:
  • Master 632 Answers
  • Posted on Aug 31, 2009
Anonymous
Master
Level 3:
President:
Answers
632
Questions
0
Helped
276555
Points
2196
While on video mode press options and select settings. Scroll down to Video quality and change to High or Normal. On Memory in use, select memory card. The length of video recording is restricted by the available space on your memory card and up to one hour per clip.
Hi How do I increase the length of time taking a video.
The time limit is set because the image sensor in the camera heats up. You need to give it some time to cool between shots. The record time is set so permanent damage will not happen to the image sensor. Sorry. That time cannot be changed.
How do i extend the rings before the answer machine cuts in on my BT6500
Set the answer delay
1. Select Menu, Answer Phone is displayed, press
Select.
2. Press (Calls) until Settings is displayed, press Select.
3.Press (Calls) to highlight either Ans. & record or
Answer only and press Select.
4. Answer delay is displayed, use < or > to display
the number of rings you want (0-9 rings or Time
saver) and select Save. Saved will be displayed.
Set the maximum message length
You can set the maximum length that an answer
machine message can be: 1 minute, 2 minutes or 3
minutes. The default setting is 3 minutes.
Select.
3. Press (Calls) to highlight Ans. & record and press
Select.
4. Press (Calls) to display Max. msg length and then
press < or > to select the length you want and
Billy from Hayward
It is in the owners handbook page 45 get it while the link last
http://www.shop.bt.com/content/uni2/documentation/8h3h/bt6500_user_guide.pdf
2helpful
Voice recorder lenght should increase how to increase help me
when you go to voice recording check first the storage to be used either phone memory or memory card storage.... set it to memory card storage in order to increase the time of voice recording..
Total recording time window won't work
I had this same issue when trying to record direct to DVD with 2.5, and could not solve it. Then, I finally ran through the wizard, and it indicated the maximum length for each level of video quality (DVD HQ, DVD LP, DVD SP, etc) - something to the effect of "At this quality, your device can record XXX minutes of video".
Once I set it to a quality level that exceeded the length I needed, I was able to proceed without any problem.
1helpful
Can not record dvd movie that is more than 103 minutes in length?
The solution is the quality settings on the DVD settings. On a 4.7Gb disk, 279 minutes at 24% quality, down to 70 minutes at best quality. Also, more will fit on the 8.5Gb DL disks. You can also use automatic quality, that will fit the video that you have compiled onto a disk, using the highest quality setting that will allow it to fit. An alternate method is to 'burn' to an image file on the HD, then use a program like 'DVDShrink' to fit on the disk.
3helpful
2answers
I have a Dazzle DVD Recorder but don't know what to put in the "recording time" field. I want to record a full 120 minute VHS tape but won't let me enter 120.
It is becuase the dazzle device is not selected as your video source. Please try to go back to step number 1 then click the box says pinnacle file capture then select the dazzle then try it again. :-)
Setting the record time on a AT&T digital answering machine
Usually there is a maximum length but the recording will end when the talking has stopped, or someone has hung up.
Motorola v9
well increase the memory card and it will extend muxh longer
3helpful
2answers
Extended recorder
how can i REINSTAL MY N72 NOKIA SOFTWARE
3answers
Video length
hi you may be able to indeed BUT it depends on how much Memory your phone has.. Often the manufacturers say that the phone can record for a certain amount of time.. BUT this is usually with the MAXIMUM amount of Memory that CAN BE installed. You may find that the amount your phone has is insufficient? Can you "Upgrade" your Memory in your phone? Thats all I can think of
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
