Retrieving Messages on the Answering Machine
Press and hold either the "Answer L1" or the "Answer L2" button, depending on the line from which you want to retrieve messages.
Retrieving Messages on the Answering MachinePress and hold either the "Answer L1" or the "Answer L2" button, depending on the line from which you want to retrieve messages.
If your message is received, you will see it in the INBOX folder.
If it has not been retrieved, retrieve it (make sure you have proper settings for the MMS to work). Highlight the message and click left softkey (options) and look for similar options to retrieve message from your network operator.
After you have retrieved it simply read like you are reading text messages.
The MMS delivery process is triggered by a special SMS
message called the "MMS Notification". The "MMS
Notification" contains a URL pointer back to the full content of the MMS
message. So when the receiving phone gets the MMS Notification, it must connect
to the URL in the notification in order to retrieve the actual message content.
The error that you include above looks like the URL cannot
be fetched.
If it worked before, but it does not work now ... then it is
possible that something has changed with regard to your firewall or network
configuration. The receiving device needs to actually connect back to host
server in order to retrieve the MMS content.
It is also possible that something has changed in the
configuration at your mobile operator. Hope it will be helpful to you.
Deleted mail goes into the TRASH folder. You can retrieve deleted messages from your Trash folder, as long as the trash hasn’t been deleted yet. To retrieve a deleted message, select the Trash folder in the folders pane, select the message or messages you want to retrieve, and drag them to your Inbox or another folder.
