Danze & Single Handle Tub And Shower Faucet  Logo
rick christensen Posted on Jan 15, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Tap won't turn off
The tap won't turn off completely water drips out of tap all the time.
lbecker478
Level 2:
  • Expert 86 Answers
  • Posted on May 22, 2014
lbecker478
Expert
Level 2:
Answers
86
Questions
Helped
31066
Points
131
You have a bad cartridge...or bad seats and springs...shut off water pull cartridge and go to lowes or plumbing supply and get parts and replace...make sure hot is on left side before putting back...turn water back on...good luck
How do you turn off water under sink to change reverse osmosis filters? I found the football shaped valve that goes to the hose. I turn the valve and water still runs so what am I doing wrong?
Open the RO tap and drain the RO tank (capture and use later). The tap will run a steady stream until tank empties. When tank empties the steady stream will switch to a drip, drip, drip,... This is normal and is the production output rate of the system.
If you capture the drips into a measured container a typical rate is 1 quart per hour, more or less given input line pressure and condition of system filters. Time how long it takes to capture a cup (8oz) and do the math.
The RO feed line is likely a piercing saddled type valve. It will take several turns (clockwise) to close the valve. Keep turning CW until it stops. With the tank empty (tap will drip, drip, drip,...) close the filter feed line valve and the drip, drip, drip will eventually stop, indicating the system no longer has water pressure.
3answers
110.18522790 washer have to turn off supply lines or it keeps dripping water into the washer
The inlet water solenoids need to be replaced. Appliance parts houses will have them.
Drip drip drip from Hand Spray!
how mach water yous a day can case it to brake loss and derip
Jun 13, 2012 • Plumbing
3helpful
2answers
My nook color has frozen screen and won't shut completely down
TRY a hard reset on the Nook if that doesn't work i know of this fantastic site BNTPrice.com that sells them for cheap. i hope this works for you
  1. Press the "n" button to display the quick nav bar.
  2. In the quick nav bar, tap the Settings icon.
  3. In the Device Settings section, tap Device Info.
  4. Tap Erase & Deregister Device.
  5. Stop. Think. Think again.
  6. If you really, really want to do this, go to Step 7. If not, tap the Back button.
  7. Tap the Erase & Deregister Device button.
Kitchen water facet won't close completly
Try this.Turn water off. Remove tap completely. Replace washer correctly.Use special tape on thread(clockwise) it will undo the tape otherwise,,,Hope this helps
Jan 14, 2012 • Plumbing
3helpful
Won't even turn on. Was flashing cup size lights on left & right and I turned it off and later tried to turn it on and it won't turn on.
The problem is often that the machine develops a leak in the hose that is rightover the transformer...the water drips onto the transformer and kills that...then you have no power to run the machine.
Here is a tip that I wrote about this problem...
Keurig OneCup Coffee Brewer will not turn on
heatman101
The rinnai 20 Infinity is perfect but have recently noted a problem. I found the basin hot water tap in the bathroom begin dripping only when the kitchen hot water tap is turned on. I don't know how...
Some taps are designed to release excess pressure but it could just be a dodgy tap washer that leaks when the pressure of hot water in pipe work builds. Change the tap washer in your tap, see if it fixes it, if not it's just the design.
2answers
2003 escape turned off while driving had no water it was dripping oil and won't turn on
I have no idea what kind of advice you would like
You could have checked the coolant in the morning
as well as the oil & still while driving you lost a head
gasket & it went into failsafe & shut off
When you say dripping oil, I don't get a good
feeling & your not saying where it is or what
you are doing with your suv.
I wouldn't be supprised if you find out
the motor is ruined,hope not
1helpful
My F & P top loader machine drips from the water inlet even when the taps are turned off. This is not a huge problem but it's irritating as I can't leave a load in the machine when the spin finishes...
Hi just read your posting.The 2 faults with this problem is faulty tap washers and faulty water valves.To stop the water coming into the machine then you must either replace the washer in the tap or replace the water valve.I can help you replace the water valve if you decide to replace it.Please reply on how you would like to proceed.Looking forward to your reply.
Slow drip near back of lid
Hi there.this may be water dripping from the injector tube where the water actually enters the bowl.It is normal to drip for a short while after the machine has just been used but if it is a constant drip then you probably have a faulty inlet valve.Try this,turn off one of the taps & see if dripping stops.if not,turn off tha other tap & see if it stops.this will tell you which of the valves are leaking.You could just turn the taps off after use,that would save having to replace it.Hope that helped you.if not then give more detail if possible please.cheers!
Top Danze Home Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Danze Home Expert? Answer questions, earn points and help others
