I need the user manual. When I turn the tv on all I get is the blue screen for videos. I don't have the original remote
SOURCE: Need user manual for GE Universal Remote Control RC94930-h
Try this. http://www.jascoproducts.com/support/download-files/GE-Universal-Remotes-Instructions.pdf
If that doesn't help you and you know the model number then try this.
http://tv.manualsonline.com/manuals/mfg/ge_appliances/ge_appliances_universal_remote_product_list.html
SOURCE: Need Hitachi TV code(s) for GE Universal Remote #24912 - thanks!
here is the 2 links for the codes, they are pdf files. hope this helps
http://www.jascoproducts.com/support/download-files/RemoteCode-4-digit.pdf
http://www.jascoproducts.com/support/download-files/RemoteCode-3-Digit-New.pdf
SOURCE: need a GE universal remote manual for sku:24912
Here you go. http://www.jascoproducts.com/support/download-files/ge-remote-instruction-eg-24912.pdf
Please rate my respose if this helped.
SOURCE: lost my manual - need tv codes
Hi! The code of a GE Universal remote for a RCA TV are 0031, 0004, 0048, 0054, 0094, 0100, 0102, 0107, 0129, 0191, 0005, 0009, 0000, 0162, 0163, 0342, 0003 ,0015, 0022, 0096, 0113, 0125, 0179, 0187, 0188. In case none of these works for your TV you can try these steps for you to program your remote conrol.
1. Manually turn on the TV.
2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
3. Press and quickly release the desired TV button. The red indicator blinks off once.
4. Press the ON-OFF button repeatedly (up to 300 times) until the TV to be controlled turns off. The red indicator blinks off with each button press.
5. Press and release ENTER to install the code.
