Microsoft Excel for PC Logo
Posted on Oct 10, 2008
Need a formula for excel
Hi
i have a spread sheet on excel it is a stock sheet
i want a formula so if my stock level goes below a certain level that i can set it will change the font colour so as to warn me that stock needs to be ordered it has to change two colours orange first just to say caution stock level getting low and red so i know that stock has to be ordered
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Oct 10, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
347
Points
Select CONDITIONAL FORMATING in Format
select FORMULA IS , CELL VALUE = > < (condition)
after this select Format
font style , COLOR
SEE IT WILL WORK CHANGE OF COLOURS ........
Formula on adding numbers on excel spread sheet
Hello Anton, Please elaborate your query ?
Regards,
Seb
I need to add a year to dates on excel spread sheet there are more than 440 diffrent dates....Please help?
I assume that the dates you want adjust are in date form and are in regular columns (or rows).
If so, then you can use a formula like this =DATE(YEAR(A3)+1,MONTH(A3),DAY(A3))
where the original date is in cell A3.
You can then copy this formula to calculate all the new dates you need, and then copy the results back over the original dates as VALUES.
1helpful
Do you have a formula in Microsoft Excel that a value can convert to a word...(Ex. 15,000 then it will convert to in words fifteen Thousand..)thanks. need immediate reply.
Hi enelrah_mel0,
You can create a function called SpellNumber using the Visual Basic Editor in the Microsoft Excel to spell the number.
  1. Please Open Microsoft Excel. Then press Alt + F11 to open the Visual Basic Editor.
  2. Then, click "Insert" option above the Visual Basic Editor window and select "Module".
  3. Then, in the Book1 Module1 (Code) window, paste the below code there. (pasted in the next post separately for your convenience)
  4. Then, press Alt+Q to close the Visual Basic Editor window.
  5. After that, please type the formula " =SpellNumber( * )" in the Excel Sheet and press the Enter Key.
  6. Then, save the Excel Sheet.
eg: =SpellNumber(A1)
Where A1 is the first cell in the excel sheet.
Good Luck!
Please post back the result and let me know if you require further assistance.
Thanks for using Fixya.
Need formula for Excel
Try using "count if blank"
I am assuming that you need the value to be on sheet 3
If you want the value to be on another sheet, it is more complicated, you will have to "paste special" the value to a different sheet.
1helpful
2answers
School Truancy Report Formula
For the same exemple you can try this:
=COUNTIF(A1:A4,"=George Washington School")
Exel
That might be too much for a spreadsheet to do. It's easy to set one up to show what you have on hand and what you took out. The links to certain projects, I would need more details about.
A better way to do it is to use Quickbooks. That way you have a history of who purchased a particular item as well as when you replenished it. Then you can generate a spreadsheet from Quickbooks as well. You can have your invoicing, receivables, and payables as well in one program.
2answers
LOOK UP AND ALLOCATE
Could you write the column names from both the sheets seprately, and one data eg. that you need. It would be easier to understand the problem.
Thanks
Proton
2answers
Excel formula creation
= (a3) minus (b3) won't do it for you?
Copying data from one sheet to another if two fileds match
Nope, sorry, although I am truly an expert at Excel formulas, I do not understand what you are trying to end up with in the final cell. We can compare a specified field with two spreadsheets - use named ranges and index/match lookup formulas. But then where you really lose me is in reading "a generic field" to find a match, and then placing what "data from another field" into what "other sheet" - ? See the confusion?
Best way to compare 2 given parameters would be to use a nested if formula, with index/match combo. Here is a simple Excel example of how such a formula could be structured:
Sample Data (columnar arangement):
A1: Part B1: Code C1: Price D1: Find Part E1: Find Code
A2: x B2: 11 C2: 5.00 D2: y E2: 12
A3: x B3: 12 C3: 6.00 D3: y E3: 11
A4: y B4: 11 C4: 7.00 D4: x E4: 12
A5: y B5: 12 C5: 8.00 D5: x E5: 11
To retrieve the price for part y with code 12 and return the value to cell F2, type the following formula in cell F2:
=INDEX($C$2:$C$5,MATCH(D2,IF($B$2:$B$5=E2,$A$2:$A$5),0))
Press CTRL+SHIFT+ENTER to enter the formula as an array formula. The formula returns the value 8.00.
To take this one step further, with range names, this example will find one value at a specified location which matches a specific row header value and column header value. Let's say the range is home values (Range=HomeVal), Column A of HomeVal contains street addresses,"row headers" (Range=StAddress), and Row 1 contains dates of the various values that are in the body of the table, "column headers" (Range=Dates). To return the specific value from the range HomeVal to another sheet, where A1=address specified and A2=date specified:
=INDEX(HomeVal,(MATCH($A$1,StAddress,0)),(MATCH($A$2,Dates,0)))
Then make sure to press CTRL+SHIFT+ENTER to enter the formula as an array formula - if you only hit enter, these types of formulas will not work properly.
Please post back if you need further help, with more details, otherwise thank you for using and rating FixYa!
Top Microsoft Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
