SOURCE: LOUD NOISE AND BURNING SMELL
How old is this dryer? If it is older that 15 years get a new one. You don't want to deal with the headaches. The motor may be going bad on it and the wiring could be melting. I assume it is not working now. Have him check the breakers. Make sure the connections are o.k. in the back. Clean out the lint piping and look for lint underneath it as well.
SOURCE: Dryer won't start and smells like something is burning
Sounds like you have lost your cycle timer or control panel.I would replace it or have it replaced.
let me know
SOURCE: screeching noise and burn smell how do I open dryer to repair
Pull it out from the wall, unplug it and remove the back panel by removing the screws. The problem is most likely the belt around the drum which is either worn out or out of alignment. Take a look at it and decide if you can just straighten it on the drum or if you will need to buy a new belt.
SOURCE: Burning Smell from Belt on Whirlpool Dryer
Hi, You need to check and see if the belt has slipped off of one of the pulleys. Was the idler the wheels style or a glide style?
Make sure the grooves in the belt are facing the drum and they are in the grooves of the motor pulley.
Please let me know if this helps and if I can assist you further.
Vic
