( one question i have is every time the ignition fuse blows do i need to replace the starter relay? ) NO ! You have a dead short to ground on one of the circuits that fuse feeds. Do you know how to find a short circuit ? Video's on youtube show how. The fuse that blows ,is it IGN - A 40 amp. located in the under hood fuse/ relay center ? That fuse feeds B+ voltage to the ignition switch ,which powers up other thing's ,fuse's etc.. Not just the starter relay ! I see five other fuse's that get power from that fuse when ignition switch is in the start or run position . In the I/P fuse panel the gauges fuse #4 10amp , air bag fuse #10 10amp , turn b/u fuse #16 20amp. , Plus trans fuse #20 10 amp ! Pull out these fuse an try to start the van. if the ignition fuse doesn't blow the problem is in one of these other fuse circuits. There is one more fuse that get's B+ power from the ignition switch and ign A fuse ,crank fuse fuse #8 10amp. this powers the control side of the starter relay .
You can find a free wiring diagram here
http://www.bbbind.com/free_tsb.html Enter vehicle info. year , make , model and engine . Under system click engine , under subsystem click starting. Click the search button then the blue link.
If you pull those fuse's i mention and it still blows the fuse look for a shorted ignition switch or wiring from ignition to the starter relay , not the relay itself. Park neutral safety switch . Isolate the circuit , pull the relay out of it's socket ,pull the crank fuse #8 in the I/P fuse box. with a ohm meter check to see if that part of the circuit is shorted to ground. Do you know how to do that ? Do you have a volt ohm meter ? You can buy one cheap at parts store .
my radio doesn't work, my door won't lock, and my interior lights on the mirror are out also.. Any suggestions as to why?
