Wont start changed fuel filter and pump
If you don'nt have spark check for power from coil.If theirs no spark coming out of the coil then replace coil.Just pull the coil wire off the distributor side and ground it against metal and have someone else crank it over while you watch for spark.Be careful don't hold wire by hand you will get shocked.
SOURCE: 99 blazer no start
it is definitely the FUEL PUMP or FILTER then ;-) - or a blockage in the line.
I have heard it said that when the Chevy fuel pump goes, it self destructs and may leave (clogging) pieces in the tank (ugh)
Pump is IN the tank, so be extremely careful if you try to fix yourself. Fuel filter us UNDER the tank and cost $11.99 at Walmart.
My pump makes noise when I turn on the Key (but not starting) and so I thought it was OK too... but a Pressure check at PepBoys showed it LOW. $351.00 to drain, clean and replace pump. (another ugh) so I toodled over to Wal Mart, bought a Fuel ffilter for $11.99 and swapped ourt (pay attention to the ARROW it must point towards the FRONT of the car ;-)
Mine was full of coffee-like tar sticky stuff, so a quick change, new clamps (Use SSteel as these will not rust) and Bang, I was OK again.
CLAMP the fuel line coming in from the tank with 2 pieces of wood and a VVise-Grip pliers or C_Clamp. Don't want a face full of gas. Do the same on the ENGINE side of the filter.
Looen the 2 hoseclamps or twist them to break of rusted, and spen some time prying off the old hoses. Put a box full of crumpled newspaper or shredded stuff *sawdust works too) under the filter (on the ground) to catch the fuel or goo that will run out of there when the hoses pop off.
I took off the clamp on the Engine side, and let the fuel from the engine run out into a jar and it was uckky goopy brown too, but the last was clear so I let it drip out. After I wiggled the hoses and pried the old one off, I loosened the 3/8 nut and bracket and slid the OLD one out, and put the NEW one in. Then I put dishsoap on the nipple of the NEW filter and inside the old hose and pushed it on, then put on the hoseclamp and screwed it down tight. I then reattached the front hose the same way, put on the clamp, and now I had a new filter on the car. I still suspected I'd have to swap pumps.. but it was a $12.00 chance I'd definitely recommend to anyone ;-)
Make sure clamps are on RIGHT and hand TIGHT, hose on all the way and both clamps 1/4 inch from filter body, then take off the tank side Vise-Grip or C_Clamp and look for leaks. OK?
Then take off the ENGINE side clamp and look for leaks. OK?
Now go turn on the key so you hear the pump, let it stop making noise, and turn key OFF. Do this 20x to get fuel into the engine again. Then PUMP the GAS pedal 3x, hold to floor and start the car. As soon as it goes, slowly pump the GAS pedal and keep it running, but not RACING the motor!, and get it to idle again by itself (all air out of the fuel line)
Now go back and look for leaks. If there are any, STOP the motor and tighten clamp(s) just a bit. You dont want the clamp to CUT or CRUSH the hoses, just hold them tight.
Well Done!!
SOURCE: 99 Chevy Blazer
Have you tested the crank sensor? sounds like no command from PCM to pulse injectors.
SOURCE: my 1996 s10 blazer wont
Like Kristisamp Said check the Fuel pump relays, they are little black box shaped fuses in the glove box, there are 3 of them, I think there may be a cover over them so you can see it......
Take the cover off and there you go......
I have a 96 blazer 2 door that had the same problem, I repalced thes relays and Bam!!! fired right up........
SOURCE: I have a 2002 chevy blazer 4.3L that wont start
are you using the original key ?? sounds wear but in the key switch there is a sensor that detects if the right key is in use otherwise it will kill the power to the fuel pump or it can be a fuse look under the left rear passanger seat there is another set of fuses and the other set of fuses are on the driver side near the door and there is another set of fuses and relays inside the hook next to the battery
