thanks for that. what does the if transformer look like ? my other sons tv, also a asda combi set also has this problem, by my 3rd son has another brand of t.v. and thats ok. something i did try was to connect my old satallite link up to the tv s and all the sound is ok. but this only happens with the new cable feeds. i tried changing for 3 different splitters but it is always ok with the sat but not the cable, so i know all connections are ok ..wierd .. thanks for your help
You can't post conmments that contain an email address.
If you wish to record (VHS) off cable :
First connect the co-ax cable from the wall to the input on the DVD/VHS , then connect a second from the output of the DVD/VHS to the input of the TV.
You will need to match the channel (3/4) output and input. There should be a switch on the back of the DVD/VHS.
Tune the TV to channel 3 or 4 to match, To watch DVD/VHS .
Channel selection will be with the DVD/VHS when it is powered on.
TV will tune to channel when the DVD/VHS is off.
It sounds like you aren't cycling fully. It sounds like you are on the TV (RF/Cable) input, then you switch input to Component 1 (for your DVD) and watch the DVD, then hit the input selector again, switching it to Component 2...you need to keep switching the input until you are back on the TV / Cable input.
Tries tv and cable box unplug,replug it back like about an hour.For the tv resetting itself and the cable box to upgraded it softwares.Go into the tv menu go to Audio SETUP.Go down to audio ressetting,these steps should solved ur problems,but not call ur cable companny replaced the reciever box,it have problems.
hi, Do one thing get a stereo RCA cable and connect its one end to the audio output of your tv and other end to the any one of the analog input of the amplifier. when you watching the tv simply select the corresponding input in your amplifier to which you have been connected the RCA cable.
Also there is one more why if the tv has an optical output. connect the optical out put of you tv to any of the optical input of the amplifier. select the corresponding input when you watch the tv ok
Before you go that far, realize that the cable itself may be the problem. Usually poor picture quality can be traced to poor cable connections. Also, another possibility is poor connections inside the tuner of the set. I assume that you are using a cable box. Some of the newer boxes have direct video connections which will connect as you describe. Check the condition of all of the cables and connectors before yo invest in anything.
Just run red and white composite audio cables from the audio out ports above the AVin1 ports on the back of the tv to one of the audio input ports on the home theater system, remember which input port you connected it to and when you want to watch tv with the home theater sound just switch to that input on the home theater system.
No, that's not going to work. Digital output is just that....Digital. Your trying to send a digital into analog....won't work. Your tv don't have red and white audio out. That's what you hook to, but it still wouldn't be 5.1. Your out of luck my friend. The ONLY way you'll get 5.1 out of that T.V. is to get a 5.1 reciever with CO-AX digital input...the SAME as whats on your T.V. You can only hook-up sound to your X-FI with the line in jack using a y-connector and 1/8" stereo plug....and it won't ever be 5.1. It can't that way. Only way to get 5.1 to work on the blaster is with the tosh-link optical input cable. This too is digital, but uses optics to send it. Remember, you are playing with 2 different formats. Analog with your white/red thing you made and then digital. Digital using co-ax or optical tosh-link. Completely different.....as you now know.
