Nedd repair manual
Max CN890II Framing Coil Nailer Parts beware for the right model / type in this link.
Hint by roof-nailers it is best to have extra attention on the upperpart , like the cilinder-cap if there is trouble unmount clean and lubricate some extra basic-lubrication, use OKS 1110 or an equivalent sillicon based lubrication for it.
The little cylinder for the nail supply also and use allways pneumolube or an other acid-free oil.
SOURCE: Magnum 34 degree framing air nailer
One dealer for this product is:JEB SUPPLY CO Customer Service Contact
Contact this seller Phone: 717-729-1056 , Some parts that seal inside nailers are actually vinyl seals called cylinder seals or firing valves that snap on the actual part, these parts must be replaced with like parts, however if you are handy with simple tools you can make a gasket very easily if the part that you are describing is bolted between two flat surfaces. You can make this gasket out of automotive gasket material. Pay attention to the thickness if the old gasket and buy the thickest material that you can find. In most cases gasket material sold at auto parts stores is thin but you can use two or three layers to make your gasket. Do not use cork gasket material. Layer two or three pieces of gasket material cut larger than you need and staple them together around the edges so that they will not shift. Coat the surface of the nailgun with light oil and press the gasket material firmly against metal to imprint pattern. Cut out gasket a little larger than imprint both inside and out and punch holes where necessary. Make sure to punch a small hole for any vents other than bolt holes. Tighten bolts very firmly. Good luck with your project. Please post again if you have more questions.
SOURCE: Paslode framing nailer loss of power.
Here's what I found at the Paslode Troubleshooting Site:
Tool will not cycle - fan runs, indicator light
is solid green.
Lockout bracket is stuck in lockout position.
Work-contacting element is bent, or build-up of
debris in track restricts operation.
Follower is not behind fasteners.
Fuel Cell empty.
Spark wire out of spark plug.
Spark plug is dirty.
No spark is generated.
Check lockout.
Remove and inspect lower probe. Clean and
lubricate track with Paslode Impulse® oil.
Repair or replace lower probe as required.
Position follower behind fasteners.
Replace fuel cell.
Remove cap and check spark lead, insert in
spark plug and replace cover.
Clean tool cylinder head and spark plug.
If this doesn't work, I suggest contacting Paslode directly 800-222-6990
SOURCE: looking for a manual for an Hitachi Framing nailer
Go to Hitachipowertools.com and type in your model number and you can download a manual for this tool
