Hi
Can you recommend any brands of USBs with built in security for password protection?
Thanks in antcipation
How can i unlock my password
Yes you can go for Sandisk Cruzer Micro or Cruzer Profile.
Cruzer Profile is very cool and it require you to swap your Finger on a built in Finger Print reader in order to access your data but that great feature comes with a little more cost but you would not need to enter your password and even need not worry about forgetting it.
Another one, Cruzer Micro comes with U3 preinstalled on it which is a set of portable programs you can run off the drive without any installation. This U3 includes a software called as Cruzer Lock that protect and encrypt your data.But remember if you forget your password you loose your data, Because even if you want tio continue using your drive you would need to reset the drive in which case data will be unrecoverable as it is encrypted with AES encryption.
I hope you got your answer,
Please revert if you need any more info.
click start control panel administrive tools computer
management device manager scroll down universal serial bus controllers you
could see a yellow question mark?
right click to reinstall drivers
if you can see your usb drive but its not working
ports(com&lpt)right click update driver if this fails to
fix the problem
check the USB leads that attach to the motherboard usually
red white green black make sure they are securely seated and have no dust build
up on them dust will cause static and a lot of unforeseen problems for a
computer and its parts
click start control panel administrive tools ,computer
management ,device manager look through all of your devices if you see a yellow
question mark?or exclamation mark ! or red x
hope this helps
