SanDisk Cruzer Micro 8GB USB 2.0 Flash Drive Logo
nico brayant Posted on Nov 15, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do i remove write-protection from my cruzer edge flash drive
Cruzer edge
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Apr 11, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
6090
Points
Go to the registry editor and remove the file protection file.type redgit on run menu then the registry editor will open.
Anonymous
Level 1:
New Friend:
  • Posted on Oct 26, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
6090
Points
Sandisk write protection error how to remove this error
and Iam not solved this error
Brian Sullivan
Level 3:
  • SanDisk Master 27,725 Answers
  • Posted on Jan 23, 2012
Brian Sullivan
SanDisk Master
Level 3:
Answers
27725
Questions
Helped
5691125
Points
79191
You will have to be the computer administrator to change any values on any hard drive
click start control panel user accounts you should see a box with the administrator and the guest account if
you have made one click on the administrator this may vary depending on which operating system you have
click start click to open on my computer you should see your usb drive E: right click select properties there will be an array of options
select the security tab option then advanced make sure you have full control in windows 7
click start click to open on my computer you should see your usb drive E: right click select properties there will be an array of options select the sharing tab option then advanced sharing make sure you have a tick in the share this folder box then click permissions make sure you have all 3 boxes ticked full control changes and read in windows 7
click start control panel user accounts click on the administrators account if you have made one or you will have to create one in windows XP
click start right click on my computer select open
Right click the icon of your usb drive (It should be E:/ or something)
Click Properties in the menu that comes up
Click the Sharing tab
Click permissions
And finally, click Allow next to Full Control.
hope this helps you
  • aletsarkar
    aletsarkar Sep 23, 2012
    this is not working.....at all in Win 7
4 Related Answers
k24674
  • 8093 Answers
  • Posted on Nov 22, 2009
SOURCE: Can I password protect my Cruzer USB 2.0 Flash
The Cuzer has its own encryption software. Plug the Cruzer in a USB 2.0 prt on the computer. If the Cruzer LaunchPad does not execute by default, use the Windows explorer to explore My computer. You will see two icons related to your cruzer, one of them is a CD_ROM. In fact it is the LaunchPad of the U3Smart OS that come swith the Cruzer.
Click on the CD-ROM icon and an a yellow icon (U3) installs on the system tray. Click on it. A pop-up window deploys. Click the Settings button on the right side (2nd menu on the right, under explore drive). You will have to configure U3 LaunchPad Settings. Select Security and enable security.
You will be prompted for a password.
Warning: If you use the Cruzer on Macs or Linux, you will not be able to open it on these OS's if security is enabled. You will be able to open it on Windows only.
Hope it helps.
Thank you for using FixYa.
Anonymous
  • 702 Answers
  • Posted on Sep 12, 2010
SOURCE: How do I password protect my ScanDisk Cruzer Mirco
Have a look at truecrypt. Should do what you want.
Anonymous
  • 702 Answers
  • Posted on Jan 05, 2010
SOURCE: how to set up a password for sandisk cruzer 4gb
You could try using TrueCrypt.
Anonymous
  • 1932 Answers
  • Posted on Jul 21, 2010
SOURCE: my Flash Drive is write protected how to remove
The procedure for removing the right protection is given in the website given below.
please follow the directions and you can remove it.
http://www.troublefixers.com/remove-write-protection-on-usb-pen-drive-or-memory-card-or-ipod/
Thanx
How to fix disk is write protected?
Try this. If you can't figure it out, either use a different USB drive, or consult an IT guy. Much of the glitchy stuff in computers these days is just too complex unless you have some training, or self education .
http://www.tomshardware.com/forum/296309-32-remove-write-protection-sandisk-cruzer-flash-drive
How do i remove write protection on a sandisk cruzer 16 gig usb device
Format it with your windows format tool then right click on it in the device control screen select "run as administrator"
How to remove write protection on my sandisk cruzer flash drive
I think the sandisk cruzer flash drive does not have a write protect switch. Please give more details about the product, model number etc. It could be possible that the "SanDisk SecureAccess software" provided with the flash drive could be protecting your drive. Open the associated application for findign out how to turn off write protection.
For more details check http://www.sandisk.in/products/usb/drives/
Write protection of flashdrive
Try this link
http://www.tomshardware.com/forum/284827-45-remove-write-protection-flash-drive
How do I remove a password from a SanDisk Cruzer Switch 32 GB USB Flash Drive
Here is a "How to" article describing how to remove the password (if you know the password.
http://www.ehow.com/how_8120645_password-off-cruzer.html
Here is a SanDisk article for retrieving the password if you don't know it.
***Caution potential data loss****
http://kb.sandisk.com/app/answers/detail/a_id/800/~/retrieving-a-forgotten-password-on-a-cruzer-enterprise-drive
1helpful
Remove write protection trick
google "hp format tool", run as adminstator
8helpful
How to remove write protection from sandisk cruzer flash drive
how do I remove write protection on my cruzer 2GB thumb drive
Feb 21, 2009 • Cameras
1helpful
Cannot remove write protection on sandisk cruzer usb pen.
The memory cards also have a write protection switch to protect data from being deleted or overwritten, just like a floppy disk
Top SanDisk Electronics - Others Experts
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
