I solved the reset by pressing the air dry and reset buttons 6 times in sequence, the whole panel array lit and I was then able to reset. I have had no problems since and have used it 6 times. I initially thought that the chipset had a volatile memory and took out the control card and checked all sensors, the falut persisted and I was so close to scrapping the thing !
We have had a few hydro outages here recently, I guess this put the machine out of sequence and it would not reset. I recommend that if you have a similar problem try pressing the buttons one after the other within 6 seconds, I guess similar machines with a slightly different touch pad use this means to unlock too so play with it for a while!
Hi
If clean light is blinking 7 times then it may be an issue
with heater circuit, door switch or wash pump. If yes then please reset the
power to the dishwasher. After, 5 minutes check if you are still getting the
same error. If yes, then it is a water heating fault. To resolve this error try
pressing this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High
Temp - Air Dry - High Temp - Air Dry or Hi Temp Scrub, energy saver dry, Hi
Temp Scrub, energy saver dry. Now let the unit run for 2-3 minutes and then
you press the Cancel/Drain button and allow it to completely drain and reset.
If this doesn't work then it's an issue with the wash pump not pumping the
water past the heater efficiently or due to lack of water to heat. Please make
sure that heater is not open circuited and is heating the water efficiently.
You'll have to check the heater using a multimeter; the meter should read
between 3000 to 3300 ohms (Use multimeter on Rx1 ohm setting). If heater is
fine then make sure water pressure is optimum and fill valve is working
fine.
Hope this helps... Please post back if you need more
information.
Daniel
