SOURCE: catalyst ws-c2926 password recovery problem
9600 baud rate
No parity
8 data bits
No stop bit
The following instructions appear:
The system has been interrupted prior to initializing the flash file system.
The following commands will initialize the flash file system, and finish loading
the operating system software:
flash_init
load_helper
boot
Directory of flash:
2 -rwx 843947 Mar 01 1993 00:02:18 C2900XL-h-mz-112.8-SA
4 drwx 3776 Mar 01 1993 01:23:24 html
66 -rwx 130 Jan 01 1970 00:01:19 env_vars
68 -rwx 1296 Mar 01 1993 06:55:51 config.text
1728000 bytes total (456704 bytes free)
Source filename [config.text]? (press Return)
Destination filename [running-config]? (press Return)
The configuration file is now reloaded.
switch(config)#enable password Cisco
switch#control/Z
switch(config)#write memory
SOURCE: I had forgotten the password of my Cisco Catalyst 3550 Switch
password recovery procedure 3550 catalyst cisco switch
1>Attach a terminal or PC with terminal emulation (for example, Hyper Terminal) to the console port of
the switch.
Use the following terminal settings:
¨ Bits per second (baud): 9600
¨ Data bits: 8
¨ Parity: None
¨ Stop bits: 1
2>Unplug the power cable.
3>Power the switch and bring it to the switch: prompt
4>Issue the flash_init command
5>Issue the load_helper command.
switch: load_helper
switch:
6>Issue the dir flash: command.
Note: Make sure to type a colon ":" after the dir flash.
7>Type rename flash:config.text flash:config.old to rename the configuration file.
8>Issue the boot command to boot the system.
switch: boot
Loading "flash:c3500xl−c3h2s−mz.120−5.WC7.bin"...###############################
9>Enter "n" at the prompt to abort the initial configuration dialog.
−−− System Configuration Dialog −−−
At any point you may enter a question mark '?' for help.
Use ctrl−c to abort configuration dialog at any prompt.
Default settings are in square brackets '[]'.
Continue with configuration dialog? [yes/no]: n
!−−− Type "n" for no.
Press RETURN to get started.
!−−− Press Return or Enter.
Switch>
!−−− The Switch> prompt is displayed.
10>At the switch prompt, type en to enter enable mode.
Switch>en
Switch#
11>Type rename flash:config.old flash:config.text to rename the configuration file with its original
name.
Switch#rename flash:config.old flash:config.text
Destination filename [config.text]
Switch#
11.
Copy the configuration file into memory.
Switch#Type rename flash:config.old flash:config.text to rename the configuration file with its original
name.
Switch#
11.
Switch#copy flash:config.text system:running−config
Destination filename [running−config]?
1131 bytes copied in 0.760 secs
Sw1#
Sw1#
12>Overwrite the current passwords that you do not know. Choose a strong password with at least one
capital letter, one number, and one special character.
Note: Overwrite the passwords which are necessary. You need not overwrite all of the mentioned
passwords.
Sw1# conf t
!−−− To overwrite existing secret password
Sw1(config)#enable secret <new_secret_password>
13>!−−− To overwrite existing enable password
Sw1(config)#enable password <new_enable_password>
!−−− To overwrite existing vty password
Sw1(config)#line vty 0 15
Sw1(config−line)#password <new_vty_password>
Sw1(config−line)#login
!−−− To overwrite existing console password
Sw1(config−line)#line con 0
Sw1(config−line)#password <new_console_password>
Write the running configuration to the configuration file with the write memory command.
Sw1#write memory
Building configuration...
[OK]
SOURCE: How to reset the cisco catalyst 2940 switch
by reset, do you mean reboot? if so type reload
if resetting to factory type erase startup-config
SOURCE: Password Recovery for Cisco Catalyst 4506
Please see Cisco's page at http://www.cisco.com/en/US/products/hw/routers/ps5199/products_password_recovery09186a0080093e12.shtml
for step by step details and more in depth instruction.
1. Reboot
2. Press the "break" button on your keyboard within 60 seconds of the power-up to put the router into ROMMON mode.
3. confreg 0x2142
4. reset
5. type, "no" when prompted to enter the initial configuration dialog.
6. enable
7. copy startup-config running-config
8. conf t
9. enable secret <password>
11. config-register 0x2102
12. reboot again
If you have the password logon and type wr erase and reboot.
http://www.cisco.com/en/US/products/hw/switches/ps607/products_tech_note09186a00800c4546.shtml
