Motorola Mobility RAZR V3 Logo
Posted on Sep 22, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Help! my phone works..everything but the screen. its blackk!
When I turn on my phone, everythign works except the black screen. It was working about an hour ago, and now suddenly it's not working. HELP!
Anonymous
Level 3:
Brigadier General:
  • Master 7,752 Answers
  • Posted on Sep 24, 2008
Anonymous
Master
Level 3:
Brigadier General:
Answers
7752
Questions
Helped
1416212
Points
13016
You need to replaced the flexcable on the phone so take it to a mobile service center and have that done.
Screen blank on x836 turns on screen blacksout help thanks
Black Screen, Working Phone [Solved] - Phones - Cell Phone General ...
www.tomsguide.com/forum/id.../black-screen-working-phone.html
Dec 14, 2015 - 12 posts - ‎10 authors
I turn my phone off and then turn it back on, same result, black screen. I then tookout the battery and put it back in, same result. I took the battery ...
Why is my screen black but everything else works ... - iFixit
https://www.ifixit.com/.../Why+is+my+screen+black+but+everythin...
iFixitThe Samsung Galaxy S3 is a multi-touch, slate-format smartphone with ... I have a problem with my phone i dropped it and it works but all i see is a black screen ! ... was fine but then a couple of mins. later the screen started turning pink and when I .... i dropped my gs3, the screen cracked & the screen stays black, everythimg ...
Phone stuck on a black screen during or after a call? Here's ...
www.smartmobilephonesolutions.com/.../cell-phone-shows-a-black-scree...
Is your phone showing a black screen after finishing a conversation and not allowing ... causes and better yet some solutions to fix this issue on your cell phone. ... phone up to your ear, so that the phone will lock (turns on the black screen), ...
Jan 04, 2016 • Cell Phones
1helpful
Samsung Galaxy S Stratosphere SCH-I405 Screen Issue
the flexes probably had been damaged by now, stratosphere is not that tough when it comes to water, unlike galaxy s3, you need a technician now for your phone to work, or better yet, look for the nearest samsung service center and bring your phone there.
1helpful
Lg optimus black screen not working properly
open the device and clean lcd connector and board with alcohol, wait 1 hours and then try, this will solve your problem, if problem persist that mean your lcd is damaged you need to change.
3helpful
3answers
How to reprogram sony ericsson xperia x10?
Hello and Welcome to FixYa!
You need to have the Data Cable for this. If you have the cable download this update utility. Download, install and run the application. Follow the one screen instructions to update your firmware. At one stage the software may prompt you that your firmware is up-to-date, proceed anyway? At that point you have to force it to reprogram.
If you have any Confusion, questions or issues regarding your problem do tell me.
Thank you for using FixYa!, Keep visiting..
If you think I was of help, your token of appreciation in the form of rating and a testimonial will be esteemed.
Concerned, Nooh
2answers
My screen will not display anyting. it is black
if incoming & outgoing is ok then change the disply.
if no incoming or outgoing then go for flashing
1helpful
HTC Touch Pro LCD Going black and then sometimes working
is there the "calendar" and "contacts" menu buttons on the bottom of the black screen?
that's what would happen to me. i just turned off the touchFLO 3D on the today screen (by going to settings, then today screen options) and it seems to not go black anymore... even after being untouched for hours.
not sure if the same thing is happening to you, but it worked for me.
1helpful
2answers
Dropped phone screen stopped working
If the screen on your 5310 is deador the backlight is not working, you can buy a replacement 5310 LCD andreplace it yourself. A new Nokia 5310 display Screen costs about 20 dollars fromebay. I wrote a detailed guide to help you put in the new Nokia 5310 screen. Check it out at the following link:
Nokia 5310 LCD Screen Replacement
Hope that helps
The screen went black
take the phone and ahve the LCD replaced
SCREEN BLACKOUT
rizr s9 - you need to change the flexcable
Guest - you have to replaced the flexcable
Top Motorola Mobility Cell Phones Experts
AFIFUL HAQUE MUFTI...
Level 1 Expert
vince
john h
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
