Samsung SGH-A877(Impression) can be unlocked using unlock code. You can get the unlock code from TheUnlockSpot.com .There you have to give your Country and current network name along with your IMEI number to get the unlock code. They will give you the unlock code along with instruction on how to unlock. Follow the instructions and unlock your Samsung SGH-A877 .
You can get the Unlock code for Samsung SGH-F480 from SuperUnlockCodes.com .There you have to give your Country and current network name along with your IMEI number to get unlock code. They will give you the unlock code along with instruction on how to unlock. Follow the instruction correctly and unlock your Samsung SGH-F480 .
There is no free unlock code available for Samsung SGH-U600 . But,You can get unlock code for cheap price from Superunlockcodes.com . There you have to give your Country and current network name along with your IMEI number to get unlock code. They will give you unlock code along with instruction on how to unlock. Follow the instruction correctly and unlock your Samsung SGH-U600 .
Hi, when a phone displays Sim lock, it means the Sim card is block and it can only be unblocked by the service provider of the network you are using. When you put wrong code, the third time it gets blocked and displays PUK code.
PUK code can be given only by your service provider which is specific for each and every mobile number.
Contact your sim customer care department over phone. Its free of cost to get the pin or puk no. If you cant contact through your phone get some other phone and contact them.
Go to the nearest service outlet of your service provider they can also help you.
There is no other go than the above procedure only your service provider can give it nobody else in this world nor any software. Go to the below link and you can confirm that the above procedure works and there is a testimonial given by the customer too.
Wayne,
if you have forgotten the security code then the only way is to get the firmware reinstalled. That is the problem with these codes. You end up deleting all the dat that you were wanting to protect.
While, if you want to remove the code then go to Tools->Phone->Security. And then select the option on phone lock. And remove the code from there.
-First try to find what games you want, search the net. -You should have .jar and .jad file format of it. -Plug-in your phone to your PC and set "Media Player". -go to your phone folder -Create a new folder, name it "Games" -Put there the .jar and .jad file of your selected game. -unplug your phone. -on the phone, press *#6984125*# -select "internals" pass word is *#9072641*# -choose number "7" , and then "1" -turn off your cellphone -turn-on it again
-and its ok.. -try different games cause others won't work
