1999 Chrysler 300M Logo
Posted on Sep 19, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
P 1684 P 700 P 160 all these codes keep coming up
P 1684 P 700 P 160 all these codes keep coming up every time i check the car codes
Don Cahala
Level 2:
Novelist:
  • Expert 239 Answers
  • Posted on Dec 23, 2011
Don Cahala
Expert
Level 2:
Novelist:
Answers
239
Questions
0
Helped
63137
Points
469
1684 Battery has been disconnected within the past 50 starts.
P700 EATX Controller DTX present
P160 Neither rich or lean is sensed at the O2 sensor.
3 Related Answers
Anonymous
  • 986 Answers
  • Posted on Nov 02, 2009
SOURCE: what does error code P 1684 mean when check engine lite is
Dodge: The battery has been disconnected within the last 50 starts
Adam Vaughn
  • 28 Answers
  • Posted on Nov 18, 2008
SOURCE: error code 1684
Error code Number P1684 Battery Disconnected Within Last 50 Starts. Check battery and connections.
Anonymous
  • 12 Answers
  • Posted on Jul 23, 2009
SOURCE: some times when i drive the cruis control light come on
gtet it checked have the code reset
I have a 03 pt cruiser turbo. For the past 10 mos the car engine light comes on and then is misfires on 2 cylinders. I have had the crank sensor replaced 3 times, cam sensor 3 times, map sensor, harness...
I don't profess to be able to solve this over this keyboard. But push come to shove I would replace the coils that are setting codes. As far as the dealer goes unless they can confirm the problem they will write NPF (no problem found)
Check engine light comes on at times and fans kick in to!
If this is the same car with the code 128 check the thermostat. You might want to look at the temp sensor and make sure its full of coolant too.
Check engine light keeps coming on my 2002 Honda civic si. After MANY times at the same Machanic he keeps throwing codes to the car resets the light. After 30 miles or more it comes back on. Things he...
if its throwing a code for cam sensor but new sensor does not fix it given the fact of recently replacing the timing chain id say it sounds like the timing was not set correctly which is causing the cam sensor to receive abnormal readings throwing the check engine light on. pull cover and check timing mark placement against specifications
2helpful
2006 suzuki forenza check engine light keeps coming on they can not fix it code P235 keeps coming on
check whether you have air sucked by the engine,or stepper motor if is fitted not working or dirty throttle body.
Volkswagen 2004 Passat check Engine light keeps coming
code p 0130 refers to the heated oxygen sensor (HO2S) 1 bank 1
code p 0139 refers to HO2S 2 bank 1 the HO2S is the ones in the exhaust manifold or pipe before the cat converter
1helpful
Yellow Check Engine (Emissions Light) keeps coming on after having my car serviced for the light.
in order to help you I would need to know what codes are causing the light to come on. If they replaced the gas cap I would assume that there is a large evap leak but the code will tell me this for sure.
You can pull the codes yourself with a code reader that you can purchase for about $50.
You can call you local parts store and see if they can do this for you.
since it has only been a week you can ask the dealer if they can check to see if the same code has returned. If it is the same code than they should be responsible for rechecking there work at no cost to you.
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_d728a59f986299fa
"Time for service" light comes on after the car
Your mechanic may have forgotten to reset the light. Also if the time for service light is your check engine light a fault code may be stored in the vehicles on board computer. Have the codes pulled to determine if a fault code is present or not. If there are non you can have the light reset, however if there is a fault code and you just reset it the light will keep coming on until the problem is corrected.
Jt fired up car (96 accord v-tech) and light was on checked sensor connector it was tight cleared code hasnt come back on!
Sometimes a bad connection will trigger a code like this, and it wont come back. Other times it will reoccur. Just keep an eye on the light and if it comes back, check the codes to see if it is the same problem that is reoccurring. I have seen this happen many times, and at this point the best thing to do is to wait and see if the light comes back on.
My EPC light keeps coming on and my car keeps turning off and the check engine light keeps coming on and the RPM is alittle over 1. and doesnt turn on most of the time! wat do i have to do or buy exactly? ...
Hi Ramiro, Before going any further you need to gather a little more evidence. Have the computer scanned for stored error codes. From what you describe your issues are intermittent and having the error code would significantly reduce the number of possibilities.
1helpful
Check Engine Soon Light
tc52 Every time your check engine light comes on there should be a code. there is no such thing as just a light coming on. there is a reason. if you take your car to a autozone or advance auto parts they will come right out and read it right in front of you and tell you what the code is and what it means when you find this out e-mail for further assistance [email protected]
Top Chrysler Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you a Chrysler Expert? Answer questions, earn points and help others
