Graco Quattro Tour Duo Stroller - Gianni Twin Seat Standard Logo
Posted on Sep 16, 2011
I need a bumper bar for the obaby zezu. Where can i find one??
3answers
How to removing the rear bumper bar
Slide under the bumper and look on the back side of it. You will find the bolts that attach it to the body.
How to remove bumper bar?
Hi
You gotta first remove the front bumper cover which is usually torx screws and clips. Grille needs to be removed too.
Once off the main crossmember will be bolted onto the chassis legs by four bolts each side.
Roger
1helpful
Hi I have a borrowed old Quinny Zapp for which I bought the Quinny Zapp Xtra seat and adaptors. Does the quinny bumper bar fit it? Thanks
Hi Maria
If you have a 2011 model Zapp Xtra seat unit the bumper bar is not suitable to use on it.
The bumper bar accessory is only suitable for 2012 model Zapp Xtra seat unit onward. On the back of the seat unit there is a manufacturing sticker which shows date of production, which will tell you if your seat is suitable for using bumper bar accessory.
4helpful
2answers
How to remove rear bumper 1999 blazer
Hi there:
Check this Removal Procedure...
1. Remove the rear bumper step pads.
2. Remove the license plate lamps.
3. Remove the nuts and the bolts that retain the rear bumper impact bar to the bumper bracket.
4. Remove the rear bumper impact bar from the vehicle.
Installation Procedure
Notice: Refer to Fastener Notice in Service Precautions.
1. Install the rear bumper impact bar to the vehicle as follows:
1.1. Position the bumper impact bar on the bumper brackets so that the holes in the impact bar are aligned with the bracket holes.
1.2. Install 2 bolt plates and 4 nuts on top of the impact bar.
1.3. Install 2 bolt and nuts through the bottom of the impact bar. Tighten the rear bumper impact bar nuts to 90 N.m (66 lb ft).
2. Install the license plate lamps.
3. Install the rear bumper step pads.
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
I purchased my quinny zapp xtra in october 2011, will the bumper bar fit this model?
Hi
No the bumper bar accessory is not compatible with Quinny Zapp Xtra 2011 model.
Bumper bar accessory can only be fitted to 2012 and 2013 model.
Hi i need instructions on how to collapse the obaby apex double pushchair? please help me!!!
hi not sure if these will help they are from the apollo version most double buggies fold tthe same
just double check with images if they look the same then these will work
http://www.obaby.co.uk/manuals/Apollo-Plus-Instructions-web.pdf
Feb 07, 2011 • Toys
2answers
14helpful
2answers
Mamas and Papas Ora Pushchair, Bumper Bar?
Call Customer care ;08452682000 ,mamas and papas.it cost 10 pounds.I get it!!!!
Mar 16, 2009 • Baby Gear
Top Graco Baby Gear Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Jay Finke
Jay Finke
Are you a Graco Baby Gear Expert? Answer questions, earn points and help others
